how to add USB 3.0 drivers for FreeNAS 9.1.1
hellohaneef
Hello
I am new for FreeNAS forum, recently we upgraded from FreeNAS 8.3 to 9.1.1, everything working fine, but i want to take backup from FreeNAS to my external USB 3.0 hard drive. when i connected USB 3.0 external hardrive, nothing showing in web GUI
hoping that required to update USB 3.0 motherboard drivers, kindly suggest.
D
dlavigne
Guest
If your intention is to backup to the USB drive, you will need to mount it from Shell first. Its devicename should start with /dev/da* (e.g. /dev/da0s1).
hellohaneef
Thanks for your reply,
we are currently using FreeNAS in production environment, everyday all our servers backup storing in FreeNAS. Disaster point of view we planned to to take all our backups into two external hard drive, one will be connect to FreeNAS and another will be outside on daily practice.
My concern is when i connected to USB 3.0 port on motherboard, the external hard drive not detecting, assuming that i need to update motherboard drivers
kindly suggest.
Right. You'll need to find the FreeBSD drivers for your USB controller and possibly recompile FreeNAS. This isn't something for the timid and my guess is that since you are asking how to add the drives you definitely don't have the experience to do this on your own.
Your best bet is to get a USB addon card that is supported in FreeNAS(search the forums for someone that added one and/or use the FreeBSD 9.1 hardware support list) and put in a request at bugs.freenas.org to have support for yours added assuming you can provide a link to the drivers for the developers to implement. Generally, if it isn't supported out of the box there's a very good chance its not supported in FreeBSD at all.
Dusan
xhci is the only USB3.0 driver in FreeBSD and it's included.
You did not provide your HW details as the forum rules require (board, chipset, ...) so it's hard to check if your HW is supported. Could you please provide output of dmesg and usbconfig after you plug in the drive?
hellohaneef
Dear Dusan
here you go
Copyright (c) 1992-2013 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 9.1-STABLE #0 r+16f6355: Tue Aug 27 00:38:40 PDT 2013
root@build.ixsystems.com:/tank/home/jkh/src/freenas/os-base/amd64/tank/home/jkh/src/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: Intel(R) Xeon(R) CPU E3-1230 v3 @ 3.30GHz (3292.45-MHz K8-class CPU)
Origin = "GenuineIntel" Id = 0x306c3 Family = 0x6 Model = 0x3c Stepping = 3
Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,<b11>,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
AMD Features2=0x21<LAHF,ABM>
Standard Extended Features=0x2fbb<GSFSBASE,TSCADJ,SMEP,ENHMOVSB,INVPCID>
TSC: P-state invariant, performance statistics
real memory = 34359738368 (32768 MB)
avail memory = 33025138688 (31495 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <ALASKA A M I>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 SMT threads
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
cpu4 (AP): APIC ID: 4
cpu5 (AP): APIC ID: 5
cpu6 (AP): APIC ID: 6
cpu7 (AP): APIC ID: 7
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ACPI Warning: FADT (revision 5) is longer than ACPI 2.0 version, truncating length 268 to 244 (20110527/tbfadt-320)
ioapic0 <Version 2.0> irqs 0-23 on motherboard
kbd1 at kbdmux0
aesni0: <AES-CBC,AES-XTS> on motherboard
cryptosoft0: <software crypto> on motherboard
acpi0: <ALASKA A M I> on motherboard
acpi0: Power Button (fixed)
acpi0: reservation of 67, 1 (4) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
xhci0: <Intel Lynx Point USB 3.0 controller> mem 0xde500000-0xde50ffff irq 16 at device 20.0 on pci0
xhci0: 32 byte context size.
usbus0 on xhci0
pci0: <simple comms> at device 22.0 (no driver attached)
pci0: <simple comms> at device 22.1 (no driver attached)
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xde512000-0xde5123ff irq 16 at device 26.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci1: <ACPI PCI bus> on pcib1
pcib2: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0
pci2: <ACPI PCI bus> on pcib2
pcib3: <ACPI PCI-PCI bridge> irq 18 at device 0.0 on pci2
pci3: <ACPI PCI bus> on pcib3
vgapci0: <VGA-compatible display> port 0xe000-0xe07f mem 0xdc000000-0xddffffff,0xde000000-0xde01ffff irq 18 at device 0.0 on pci3
pcib4: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> irq 19 at device 0.0 on pci4
pci5: <ACPI PCI bus> on pcib5
pcib6: <ACPI PCI-PCI bridge> irq 16 at device 28.4 on pci0
pci6: <ACPI PCI bus> on pcib6
igb0: <Intel(R) PRO/1000 Network Connection version - 2.3.9> port 0xd000-0xd01f mem 0xde400000-0xde47ffff,0xde480000-0xde483fff irq 16 at device 0.0 on pci6
igb0: Using MSIX interrupts with 5 vectors
igb0: Ethernet address: 74:d0:2b:99:a8:04
igb0: Bound queue 0 to cpu 0
igb0: Bound queue 1 to cpu 1
igb0: Bound queue 2 to cpu 2
igb0: Bound queue 3 to cpu 3
pcib7: <ACPI PCI-PCI bridge> irq 17 at device 28.5 on pci0
pci7: <ACPI PCI bus> on pcib7
igb1: <Intel(R) PRO/1000 Network Connection version - 2.3.9> port 0xc000-0xc01f mem 0xde300000-0xde37ffff,0xde380000-0xde383fff irq 17 at device 0.0 on pci7
igb1: Using MSIX interrupts with 5 vectors
igb1: Ethernet address: 74:d0:2b:99:a8:05
igb1: Bound queue 0 to cpu 4
igb1: Bound queue 1 to cpu 5
igb1: Bound queue 2 to cpu 6
igb1: Bound queue 3 to cpu 7
pcib8: <ACPI PCI-PCI bridge> irq 18 at device 28.6 on pci0
pci8: <ACPI PCI bus> on pcib8
igb2: <Intel(R) PRO/1000 Network Connection version - 2.3.9> port 0xb000-0xb01f mem 0xde200000-0xde27ffff,0xde280000-0xde283fff irq 18 at device 0.0 on pci8
igb2: Using MSIX interrupts with 5 vectors
igb2: Ethernet address: 74:d0:2b:99:a8:06
igb2: Bound queue 0 to cpu 0
igb2: Bound queue 1 to cpu 1
igb2: Bound queue 2 to cpu 2
igb2: Bound queue 3 to cpu 3
pcib9: <ACPI PCI-PCI bridge> irq 19 at device 28.7 on pci0
pci9: <ACPI PCI bus> on pcib9
igb3: <Intel(R) PRO/1000 Network Connection version - 2.3.9> port 0xa000-0xa01f mem 0xde100000-0xde17ffff,0xde180000-0xde183fff irq 19 at device 0.0 on pci9
igb3: Using MSIX interrupts with 5 vectors
igb3: Ethernet address: 74:d0:2b:99:a8:07
igb3: Bound queue 0 to cpu 4
igb3: Bound queue 1 to cpu 5
igb3: Bound queue 2 to cpu 6
igb3: Bound queue 3 to cpu 7
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xde511000-0xde5113ff irq 23 at device 29.0 on pci0
usbus2: EHCI version 1.0
usbus2 on ehci1
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf070-0xf077,0xf060-0xf063,0xf050-0xf057,0xf040-0xf043,0xf020-0xf03f mem 0xde510000-0xde5107ff irq 19 at device 31.2 on pci0
ahci0: AHCI v1.30 with 6 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich3: <AHCI channel> at channel 3 on ahci0
ahcich4: <AHCI channel> at channel 4 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
pci0: <serial bus, SMBus> at device 31.3 (no driver attached)
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
uart1: <16550 or compatible> port 0x2f8-0x2ff irq 3 on acpi0
ppc1: <Parallel port> port 0x378-0x37f irq 5 on acpi0
ppc1: Generic chipset (NIBBLE-only) in COMPATIBLE mode
ppbus0: <Parallel port bus> on ppc1
lpt0: <Printer> on ppbus0
lpt0: Interrupt-driven port
orm0: <ISA Option ROMs> at iomem 0xc0000-0xc7fff,0xc8000-0xc8fff,0xc9000-0xc9fff on isa0
sc0: <System console> at flags 0x100 on isa0
sc0: CGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3d0-0x3db iomem 0xb8000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
ppc0: cannot reserve I/O port range
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
p4tcc0: <CPU Frequency Thermal Control> on cpu0
coretemp1: <CPU On-Die Thermal Sensors> on cpu1
est1: <Enhanced SpeedStep Frequency Control> on cpu1
p4tcc1: <CPU Frequency Thermal Control> on cpu1
coretemp2: <CPU On-Die Thermal Sensors> on cpu2
est2: <Enhanced SpeedStep Frequency Control> on cpu2
p4tcc2: <CPU Frequency Thermal Control> on cpu2
coretemp3: <CPU On-Die Thermal Sensors> on cpu3
est3: <Enhanced SpeedStep Frequency Control> on cpu3
p4tcc3: <CPU Frequency Thermal Control> on cpu3
coretemp4: <CPU On-Die Thermal Sensors> on cpu4
est4: <Enhanced SpeedStep Frequency Control> on cpu4
p4tcc4: <CPU Frequency Thermal Control> on cpu4
coretemp5: <CPU On-Die Thermal Sensors> on cpu5
est5: <Enhanced SpeedStep Frequency Control> on cpu5
p4tcc5: <CPU Frequency Thermal Control> on cpu5
coretemp6: <CPU On-Die Thermal Sensors> on cpu6
est6: <Enhanced SpeedStep Frequency Control> on cpu6
p4tcc6: <CPU Frequency Thermal Control> on cpu6
coretemp7: <CPU On-Die Thermal Sensors> on cpu7
est7: <Enhanced SpeedStep Frequency Control> on cpu7
p4tcc7: <CPU Frequency Thermal Control> on cpu7
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe0005e23480 with IPv6 initialized (100409)
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
load_dn_sched dn_sched RR loaded
usbus0: 5.0Gbps Super Speed USB v3.0
usbus1: 480Mbps High Speed USB v2.0
usbus2: 480Mbps High Speed USB v2.0
ugen0.1: <0x8086> at usbus0
uhub0: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
ugen1.1: <Intel> at usbus1
uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ugen2.1: <Intel> at usbus2
uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
ada0: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada0: Command Queueing enabled
ada0: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada0: quirks=0x1<4K>
ada0: Previously was known as ad4
ada1 at ahcich1 bus 0 scbus1 target 0 lun 0
ada1: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: Command Queueing enabled
ada1: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada1: quirks=0x1<4K>
ada1: Previously was known as ad6
ada2 at ahcich2 bus 0 scbus2 target 0 lun 0
ada2: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada2: quirks=0x1<4K>
ada2: Previously was known as ad8
ada3 at ahcich3 bus 0 scbus3 target 0 lun 0
ada3: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: Command Queueing enabled
ada3: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada3: quirks=0x1<4K>
ada3: Previously was known as ad10
ada4 at ahcich4 bus 0 scbus4 target 0 lun 0
ada4: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada4: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada4: Command Queueing enabled
ada4: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada4: quirks=0x1<4K>
ada4: Previously was known as ad12
ada5 at ahcich5 bus 0 scbus5 target 0 lun 0
ada5: <WDC WD30EFRX-68AX9N0 80.00A80> ATA-9 SATA 3.x device
ada5: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada5: Command Queueing enabled
ada5: 2861588MB (5860533168 512 byte sectors: 16H 63S/T 16383C)
ada5: quirks=0x1<4K>
ada5: Previously was known as ad14
SMP: AP CPU #1 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #5 Launched!
SMP: AP CPU #6 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #7 Launched!
SMP: AP CPU #2 Launched!
Timecounter "TSC-low" frequency 1646222716 Hz quality 1000
Root mount waiting for: usbus2 usbus1 usbus0
uhub2: 2 ports with 2 removable, self powered
uhub1: 2 ports with 2 removable, self powered
uhub0: 21 ports with 21 removable, self powered
ugen2.2: <vendor 0x8087> at usbus2
uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.04, addr 2> on usbus2
ugen1.2: <vendor 0x8087> at usbus1
uhub4: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.04, addr 2> on usbus1
uhub4: 6 ports with 6 removable, self powered
uhub3: 6 ports with 6 removable, self powered
ugen0.2: <SanDisk> at usbus0
umass0: <SanDisk Cruzer Fit, class 0/0, rev 2.00/1.22, addr 1> on usbus0
Trying to mount root from ufs:/dev/ufs/FreeNASs2a [ro]...
mountroot: waiting for device /dev/ufs/FreeNASs2a ...
da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: <SanDisk Cruzer Fit 1.22> Removable Direct Access SCSI-5 device
da0: 40.000MB/s transfers
da0: 3819MB (7821312 512 byte sectors: 255H 63S/T 486C)
da0: quirks=0x2<NO_6_BYTE>
WARNING: /data was not properly dismounted
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
GEOM_RAID5: Module loaded, version 1.1.20110927.40 (rev 00ce00e5abb4)
GEOM_ELI: Device ada0p1.eli created.
GEOM_ELI: Encryption: AES-XTS 256
GEOM_ELI: Crypto: hardware
GEOM_ELI: Device ada1p1.eli created.
GEOM_ELI: Device ada2p1.eli created.
GEOM_ELI: Device ada3p1.eli created.
GEOM_ELI: Device ada4p1.eli created.
GEOM_ELI: Device ada5p1.eli created.
igb0: link state changed to UP
ugen0.3: <StoreJet Transcend> at usbus0
umass1: <StoreJet Transcend StoreJet Transcend, class 0/0, rev 2.00/0.02, addr 2> on usbus0
da1 at umass-sim1 bus 1 scbus7 target 0 lun 0
da1: <StoreJet Transcend GN00> Fixed Direct Access SCSI-2 device
da1: 40.000MB/s transfers
da1: 476940MB (976773168 512 byte sectors: 255H 63S/T 60801C)
da1: quirks=0x2<NO_6_BYTE>
GEOM_ELI: Detached ada0p1.eli on last close.
GEOM_ELI: Detached ada1p1.eli on last close.
GEOM_ELI: Detached ada2p1.eli on last close.
GEOM_ELI: Detached ada3p1.eli on last close.
GEOM_ELI: Detached ada4p1.eli on last close.
GEOM_ELI: Detached ada5p1.eli on last close.
GEOM_ELI: Device da1p1.eli created.
GEOM_ELI: Detached da1p1.eli on last close.
ugen0.3: <StoreJet Transcend> at usbus0 (disconnected)
umass1: at uhub0, port 5, addr 2 (disconnected)
(da1:umass-sim1:1:0:0): got CAM status 0x44
(da1:umass-sim1:1:0:0): fatal error, failed to attach to device
(da1:umass-sim1:1:0:0): lost device - 0 outstanding, 4 refs
(da1:umass-sim1:1:0:0): removing device entry
USB Confi
ugen0.1: <XHCI root HUB 0x8086> at usbus0, cfg=0 md=HOST spd=SUPER (5.0Gbps) pwr=SAVE (0mA)
ugen1.1: <EHCI root HUB Intel> at usbus1, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=SAVE (0mA)
ugen2.1: <EHCI root HUB Intel> at usbus2, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=SAVE (0mA)
ugen2.2: <product 0x8000 vendor 0x8087> at usbus2, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=SAVE (0mA)
ugen1.2: <product 0x8008 vendor 0x8087> at usbus1, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=SAVE (0mA)
ugen0.2: <Cruzer Fit SanDisk> at usbus0, cfg=0 md=HOST spd=HIGH (480Mbps) pwr=ON (200mA)
Dusan
Was the drive still connected when you ran the commands?
Dusan
I asked you to connect the drive and run the commands!
hellohaneef
Dear Dusan
sorry for my mistake, currently i attached USB drive and ran this command.
kbd1 at kbdmux0
usbus0 on xhci0
usbus1 on ehci0
usbus2 on ehci1
kbd0 at atkbd0
ugen0.3: <Unknown> at usbus0 (disconnected)
usbconfig
Dusan
What drive are you trying to connect? A 500 GB Transcend StoreJet?
Dusan
Your USB3.0 controller is recognized and the drive was properly connected as da1 once:
[PANEL]ugen0.3: <StoreJet Transcend> at usbus0
da1: quirks=0x2<NO_6_BYTE>[/PANEL]
Something is messed up right now, but I'm quite sure that if you reboot and connect the drive it will appear here: Storage->Volumes->View Disks.
hellohaneef
Dear Dusan
before i connected to USB 2.0 port, and it showed me connected, i am trying to connect same hard drive on USB 3.0 port but no luck
Dusan
Here you can see that it was connected to usbus0:
usbus0 seems to be USB3.0 in your case:
[PANEL]xhci0: <Intel Lynx Point USB 3.0 controller> mem 0xde500000-0xde50ffff irq 16 at device 20.0 on pci0
usbus0 on xhci0[/PANEL]
hellohaneef
for some reason its not showing in GUI
