how smart is FreeNAS?
Zedicus
So my critical light was on this morning and upon investigation it showed a failed drive, however when I go in and look at the volume that drive is not associated with the volume that the error says. I do have a bunch of blank drives in the server from a secondary build I never got completed. Did FreeNAS just automagically grab one of those after the drive failed and rebuild itself?
wblock
Documentation Engineer
FreeNAS will not use blank drives. If those drives are added to a volume as spares, they can be used.
pschatz100
It will be possible to help you better if you will provide a copy of the error message and the details of your build.
Check the forum rules for guidance on what information to post.
zpool status and smartctl -a /dev/adaX for all drives would be a good start.
Zedicus
i got this sorted out. the diskinfo utility is actually usually the most useful. my chassis doesnt have a failed disk light and the order that freenas grabs and labels /dev/da# seems to be random when looking at the chassis. (i am sure it is logical to it, sas address or guid or something, but i have never bothered to actually figure out how it assigns the /dev/da#)
also found a pool that was not doing any smart checks, and of course that is a pool where drive errors were coming from. good times.
