How do I temporarily mount an Ubunutu OS drive to pull data from it?
protectron
Below is the error I am experiencing. I cannot install LVM2 package due to lack of 'apt'.
How do I mount the drive?
jgreco
Resident Grinch
You don't. I'm pretty sure LVM2 is not installed because TrueNAS uses ZFS. Put your disk into a PC, mount the filesystem, and then mount the NAS share or use netcat to bap it across the net.
