redundantly
- Dec 5, 2016
I've got this directory:
And I need to share it with two separate clients via NFS with different permissions:
If I try to set this up with two different shares pointed at the same directory I get the following error:
I've seen other threads where this is called out as a bad practice and the way to do this is use separate datasets, but this isn't possible in this scenario since I need two different clients to access the exact same data with different permissions.
How do I accomplish this with FreeNAS?
/mnt/tank/nvr/recordingsAnd I need to share it with two separate clients via NFS with different permissions:
- 192.168.2.101 with write access
- 192.168.2.212 with read-only access
The network 0.0.0.0/0 is already being shared and cannot be used twice for the same filesystemI've seen other threads where this is called out as a bad practice and the way to do this is use separate datasets, but this isn't possible in this scenario since I need two different clients to access the exact same data with different permissions.
