I followed instructions on how to move my swap partition to another drive but it seems as though it's not being used and when i run swapinfo i don't get what the instructions suggest i should.
xeon e3-1340L
32GB ecc ram
supermicro x11ssh-f motherboard
latest stable version of TNC.
TNC is installed on mirrored SSD's
the motherboard has an M.2 slot for an NVME and i had one laying around that i wasn't going to use so i figured i'd install it, disable all the swap space and just have TNC use the nvme as a dedicated swap drive.
running swapinfo command yields the following:
i would think /dev/mirror shouldn't show up
i wan't /dev/gptid/yadda yadda to be the swap drive.
anyone have any tips?
thanks!
xeon e3-1340L
32GB ecc ram
thanks!
