How do I check current pool activity?
Octopuss
Or more specifically, what the current, say read transfer rate of the pool in MB/s is?
I absolutely don't understand the reports window at all.
There are da1-3 disks in the system, but reports list cd0 and da0 on top of that. There's no way to select the pool itself either, as far as I can tell...
Octopuss
The latest.
colmconn
From the command line (I'd recommend you ssh in to the box you can use zpool to show you the activity on the pool. For example
zpool iostat -T d ssd 5 10
which shows the activity on the pool named 'ssd' in 5 sec intervals for 10 repetitions with a time stamp (-T d) will result in the following output:
               capacity     operations    bandwidth
pool        alloc   free   read  write   read  write
ssd         41.0G   180G      4    118  73.2K  1.04M
Fri May 17 09:17:01 EDT 2019
ssd         41.0G   180G      1    108  8.00K   702K
Fri May 17 09:17:06 EDT 2019
ssd         41.0G   180G      0    142    818  1.04M
Fri May 17 09:17:11 EDT 2019
ssd         41.0G   180G      0    114      0   689K
Fri May 17 09:17:16 EDT 2019
ssd         41.0G   180G      0     91    818   611K
Fri May 17 09:17:21 EDT 2019
ssd         41.0G   180G      0    106    817   652K
Fri May 17 09:17:26 EDT 2019
ssd         41.0G   180G      0    110      0   841K
Fri May 17 09:17:31 EDT 2019
ssd         41.0G   180G      0    135      0  1.09M
Fri May 17 09:17:36 EDT 2019
ssd         41.0G   180G      0     97    818   619K
If you're interested in the activity on the raw drives you can use gstat. For example, to show only information for drives named da0, da1, da10, etc and ada0, ada1, ada10 etc you can use a command such as
gstat -f 'a?da[0-9]+$'
gstat will by default include info on all geom devices, much of which I find redundant hence the filter.
Octopuss
Wait, there's nothing like that in the GUI? Um, why? It shows wholw bunch of useless stuff, but not current transfer speeds?
