Hi, I want to backup a TrueNAS VM after the initial setup to another TrueNAS machine in case the original server goes capult for some reason.
First thing I tried was replication, but while the VM has 304 GiB the replicated image was nearly empty. So then when I did a "du -h" on that mount point I found that the actual storage used by the VM is not accounted for in the file system. That is a 444 GiB pool and only 140 GiB is accounted for -- i.e. the 304 GiB used by the VM do not seem to be part of the visible file system.
Any thoughts on what is going on, and more importantly, how can I make a copy of the VM for posterity?
Thanks!!
$ cd /mnt/OVERVOLT
$du -h
<snip>
OVERVOLT 140G 252K 140G 0% /mnt/OVERVOLT
OVERVOLT/My-VM 140G 88K 140G 0% /mnt/OVERVOLT/My-VM
<snip>
$ cd /mnt/OVERVOLT/My-VM
$ ls -la
drwxrwxr-x+ 2 root vmking 2 Nov 8 2021 .
drwxr-xr-x 4 root wheel 4 Nov 8 2021 ..
Thanks!!
