How can I start a program automatically?
ObiTobi
I'm using software to sync my data between NAS and my Windows/OSX clients. How do I set it to start automatically after rebooting?
Chris Moore
You first need to tell what software you are using and where that software is running. The thing you have told us leaves too many things up to our imagination.
When I have done something like this before, I ran the backup utility as a scheduled task on the PC. That avoids all sorts of problems with having the backup run.
ObiTobi
I use Syncovery and for FreeBSD SyncoveryRS (Syncovery Remote Service).
The only one thing I need is how to create a Cron Job that will be startet only after reboot. The GUI does not allow
Chris Moore
How is it possible to install the software on FreeNAS? It should be in a jail. You have not yet explained what you think you want.
If it is in a jail, the cron job of the jail is what needs to be configured.
ObiTobi
I don't think I know what you mean by that. You can copy file to where, in that case to /usr/local/sbin
And no, it's not and it won't be a jail.
What I need is a cron job that does run after reboot. Nothing else.
Chris Moore
Have you tried rebooting the system since you copied software onto it?
You may find that things that you add to FreeNAS don't survive a reboot. You are not supposed to be able to add software to FreeNAS other than adding a jail and putting the software in the jail. If you are not listening, figure it out on your own.
ObiTobi
Maybe I didn't understand you but so far you haven't even begun to answer my question. Well, I'm already listening.
So the question was not how the software comes on NAS but how I create a special cron job.
By the way - when I put the software into a jail it doesn't change the fact that I have to do a cron job - the same problem. And now?
garm
Don’t expose your core system to these kinds of tools, use jails. It’s what they where built for. In the jail the link is valid. If you do it in core FreeNAS just use the GUI, but don’t. It’s opening yourself up to a world of hurt.
Jailer
Not strong, but bad
This can't work because FreeNAS is always regenerating crontab file after each reboot.
That's why you install it in a jail as suggested.
Chris Moore
But now I found a solution for me. /I will check it later if it really works in every situation as I want it to./
You really should not add an application to FreeNAS. I don't know what solution you have come up with, but it is doubtless a bad one.
ObiTobi
I'm sure you're right about the jails. Maybe I didn't understand everything about jails - e.g. why do I have to choose an IP address for each jail?
And how can I create something like jail-template that the syncovery manufacturer can always deliver without the end users having to do anything?
/I know for myself that my current solution is not optimal and not for everyone. /
Chris Moore
Each jail gets it's own IP address because it is a para-virtual machine that has it's own separate configuration where you can install a software package and create a cron job that will run more like it is in a standalone BSD install.
Are you one of the developers of this application? I just wonder why you want to create a template to make it easy for other users to configure?
It can be done, but FreeNAS is in the process of moving from warden jails to iocage jails, so the way of going about it is the question.
@Jailer what do you say?
Jailer
Not strong, but bad
Well the developers would have to port it to FeeBSD and get it added to the repository. That's something you'll have to take up with the Syncovery developers or maybe someone in their community.
As far as getting it to run via startup you'll likely have to create a startup script and call it when the jail starts. The link @garm posted will help get you going in the right direction or you can set up a cron task in the FreeNAS GUI to start it.
MrToddsFriends
Documentation Browser
If I didn't miss vital points of the discussion there were two points that got mixed up so far.
First, if the Syncovery software used for synchronization already is available as a self-contained or even statically linked FreeBSD executable which doesn't have to be installed via an installer but only copied to an arbitrary location, it's not necessary to go the jail route. In this case just copy the executable (or "binary") to a folder which survives FreeNAS updates.
/root/local/sbin or /home/<arbitrary_user>/local/sbin would be examples for such folders (would have to be created by a user with adequate permissions).
Second, there might be some mix-up regarding cron jobs and init scripts. Both can be configured using the FreeNAS GUI (at least as long as no stuff inside a jail is involved). Init scripts are used to schedule commands to run at system startup as opposed to cron jobs which run commands on a regular schedule.
http://doc.freenas.org/11/tasks.html#init-shutdown-scripts
http://doc.freenas.org/11/tasks.html#cron-jobs
Jailer
Not strong, but bad
True but you can also make a crontab entry in a jail with @reboot /path/to/script and it will execute the script when the jail starts.
