I just did an upgrade from Freenas 11.3-U5 to Truenas 12.0-U5. I had a dataset freenas-boot/CUSTOM which I mounted as /CUSTOM under Freenas 11.3-U5.
After the upgrade if I attempt to access /CUSTOM from a root shell it appears as an empty directory, but before the upgrade it had many directories and files.
I know the data is stall there because when I attempt to list the dataset, I get the following:
I am assuming I need to do something to change the mount point, but I have no clue about how to do that. The complete listing seems to imply that it is correctly mounted. Any assistance is much appreciated.
# zfs list -t all -r freenas-boot/CUSTOM NAME USED AVAIL REFER MOUNTPOINT freenas-boot/CUSTOM 170M 90.3G 81.7M /CUSTOM freenas-boot/CUSTOM@__MANUAL_PROTECT_2021-03-25_02.02.29 56K - 81.7M - freenas-boot/CUSTOM@PREUPDATE 8K - 81.7M -
NAME USED AVAIL REFER MOUNTPOINT freenas-boot 17.2G 90.3G 176K none freenas-boot/.system 238M 90.3G 4.37M legacy freenas-boot/.system/configs-66c5ca0d9b594eb08a0e7191ec86e4a6 152M 90.3G 152M legacy freenas-boot/.system/configs-9d613bc4d69d4caa9ab03b2439285b53 136K 90.3G 136K legacy freenas-boot/.system/cores 136K 1024M 136K legacy freenas-boot/.system/rrd-66c5ca0d9b594eb08a0e7191ec86e4a6 56.5M 90.3G 56.5M legacy freenas-boot/.system/rrd-9d613bc4d69d4caa9ab03b2439285b53 3.85M 90.3G 3.85M legacy freenas-boot/.system/samba4 1.12M 90.3G 588K legacy freenas-boot/.system/samba4@update--2020-12-19-10-38--11.3-U4.1 360K - 588K - freenas-boot/.system/samba4@update--2021-08-14-05-54--11.3-U5 168K - 548K - freenas-boot/.system/services 144K 90.3G 144K legacy freenas-boot/.system/syslog-66c5ca0d9b594eb08a0e7191ec86e4a6 19.5M 90.3G 19.5M legacy freenas-boot/.system/syslog-9d613bc4d69d4caa9ab03b2439285b53 296K 90.3G 296K legacy freenas-boot/.system/webui 136K 90.3G 136K legacy freenas-boot/CUSTOM 170M 90.3G 81.7M /CUSTOM freenas-boot/CUSTOM@PREUPDATE 8K - 81.7M - freenas-boot/ROOT 16.7G 90.3G 136K none freenas-boot/ROOT/11.0-U3 232K 90.3G 970M / freenas-boot/ROOT/11.0-U4 248K 90.3G 973M / freenas-boot/ROOT/11.1-RELEASE 424K 90.3G 1.08G / freenas-boot/ROOT/11.1-U4 452K 90.3G 1.09G / freenas-boot/ROOT/11.1-U5 452K 90.3G 1.10G / freenas-boot/ROOT/11.1-U6 572K 90.3G 1.10G / freenas-boot/ROOT/11.1-U6.3 440K 90.3G 1.04G / freenas-boot/ROOT/11.1-U7 9.32G 90.3G 1.07G / freenas-boot/ROOT/11.1-U7@2017-09-20-01:21:53 4.05M - 980M - freenas-boot/ROOT/11.1-U7@2017-09-19-23:36:41 4.06M - 980M - freenas-boot/ROOT/11.1-U7@2017-09-29-02:04:28 969M - 970M - freenas-boot/ROOT/11.1-U7@2017-12-15-20:16:16 971M - 973M - freenas-boot/ROOT/11.1-U7@2018-05-03-01:15:15 1.08G - 1.08G - freenas-boot/ROOT/11.1-U7@2018-06-18-15:51:46 1.09G - 1.09G - freenas-boot/ROOT/11.1-U7@2018-10-11-17:12:16 1.09G - 1.10G - freenas-boot/ROOT/11.1-U7@2019-01-16-03:04:16 1.09G - 1.10G - freenas-boot/ROOT/11.1-U7@2019-01-29-15:38:10 1.04G - 1.04G - freenas-boot/ROOT/11.2-U7 344K 90.3G 1.02G / freenas-boot/ROOT/11.2-U8 352K 90.3G 1.02G / freenas-boot/ROOT/11.3-U4.1 336K 90.3G 1.42G / freenas-boot/ROOT/11.3-U5 328K 90.3G 1.49G / freenas-boot/ROOT/FreeNAS-12.0-U5 7.40G 90.3G 1.62G / freenas-boot/ROOT/FreeNAS-12.0-U5@2019-11-28-16:20:43 1017M - 1018M - freenas-boot/ROOT/FreeNAS-12.0-U5@2020-04-09-04:04:54 1.01G - 1.02G - freenas-boot/ROOT/FreeNAS-12.0-U5@2020-09-15-02:17:11 1.01G - 1.02G - freenas-boot/ROOT/FreeNAS-12.0-U5@__MANUAL_PROTECT_2020-09-25_05.57.36 1.02M - 1.42G - freenas-boot/ROOT/FreeNAS-12.0-U5@2020-12-19-05:37:00 1.41M - 1.42G - freenas-boot/ROOT/FreeNAS-12.0-U5@__MANUAL_PROTECT_2021-05-31_13.30.33 26.1M - 1.46G - freenas-boot/ROOT/FreeNAS-12.0-U5@2021-08-14-01:52:46 1.50M - 1.49G - freenas-boot/ROOT/Initial-Install 8K 90.3G 980M legacy freenas-boot/ROOT/default 232K 90.3G 980M legacy freenas-boot/ROOT/default-20190917-081209 360K 90.3G 1018M legacy freenas-boot/grub 7.94M 90.3G 7.94M legacy
