How are tasks configured in Freenas
zyz
Hi All
FreeNAS 11.1U6 up to date
Trying to debug and possibly modify the cloud sync task directly as the option I need is not available in the gui.
Seems that Freenas tasks use something other than cron to run. Can someone point me at doc that explains how the Freenas task system works and where the configuration information lies?
Cheers
Steve
D
dlavigne
Guest
Which option do you need? If it's not in the UI it's most likely not exposed by the middleware.
