B34N
 - Jul 6, 2014
Looking to build a FreeNAS server for personal home use. I'm thinking RAIDZ3 which is likely overkill for my needs since most data will be from my media server and only some data (small percentage) will be critical data I can't risk loosing. Considering the added convenience relative to incremental cost, I'm just planning on storing all data in my home (Ubuntu, Android and Win8) on the NAS. I'll run Plex Media Server, SABnzbd, CouchPotato, Sick Beard and Head Phones. I will likely also want to run MythTV backend later. There will be some very limited transcoding for now and I don't ever anticipate needing the ability to transcode much more than one item at a time. A very big plus will be the ability to play live TV through my HDHR prime cable card.
Power supply: Already own Corsair CS450M (modular ATX) but will buy new if recommended
Case: I want rack-mount. 4U no problem but would likely prefer 2U
HDs: I'm thinking four 3TB-4TB. WD Reds? Or are HGSTs, Seagates or something else just as good?
MB + CPU: No clue – Thinking ASRock C2550D4I since it seems popular. I'm not overly price sensitive but want to future-proof a bit without overspending. I can see this system meting my needs for a decade if done right.
Memory: 16GB ECC – Crucial? Should I go to 32GB initially or add another 16 or + GB later in the remaining slots?
I'm looking for something that “just works” and would really appreciate some fill in the blanks for the above. Am I missing anything?I'm thinking about a microSD with USB adapter for the OS just so I don't have big stick protruding from the case. Any reason why I shouldn't do that?
Thank you,
B34N
Thank you,
B34N
