korrupto77
- Jan 2, 2013
Hi all,
I'd like to hide in order to keep as cleanest as possibile shares. I'm just moved from form AFP to SMB and one think i've noted is the behaviour of smb shows all shares to all user differently from AFP. In the attached sketch, i've represented a pool's structure in order to let you better understand the situation.On finder zeroconf announce Freenas and the mounted from user it shows share 1 & 2. What i'd like to achieve (that was working on AFP), is hide share1 to a group (B). I've tried with "Access Share Enumaeration" but works only with sub dataset and doesn't help.
The reason for do not move Dataset 1 to Dataset 2 is maintain a separate share in order to allows certain IP only.
Thanks in advance for help
