Help, zfs continue failing with pool I/O failures
Constantin.FF
Hi everyone,
I got into complicated issue with my TrueNAS.
SSD and HDD drives are failing after couple of months, I have tested and debug, what I can, without any result. I am posting details on my configuration (old PC) and what I have tried so far.
2xSSD - PNY CS900 120GB
2xSSD - Kingston 120GB A400
1xHDD - Toshiba N300 NAS 14 TB
Two SSD are for the boot-pool - these are still stable and working 1 year later - no errors so far.
The other two SSD I am using for Applications and Kubernetes.
These started working fine but after two months one failed on the SMART test.
Error `CRC_Error_Count`. Shortly after that it stopped even being detected by the PC. (I assumed cheap ssd and I got it replaced )
3 more SSD I have changed since then, and they fail with the same error.
Now the HDD gets the same error :/
SMART fails with "CRC_Error_Count" and zfs error is:
The number of I/O errors associated with a ZFS device exceeded acceptable levels. ZFS has marked the device as faulted.
I have tried/tested:
  1. Changed the SATA cables - CRC_Error_Count should be related to something with the disk connection - Same error continues
  2. I got Dell H310 6Gbps SAS HBA LSI 9211-8i PCI-e card - still same errors
  3. Run MemTest86 - RAM is OK
  4. Try Ubuntu and run the Disk utility - SMART tests (short and long) are good
  5. Using Try Ubuntu I formatted the disk as ext4 and fill the disk with data - No errors
  6. After all I ran TrueNAS, created pool with the SSD and set some Applications to test. All good, SMART tests run without errors. Until after 7-8 hours when the same errors started again.
Motherboard: ASUS B85M-G, Socket-1150
CPU: Intel i7 3.5 Ghz
RAM: Patriot 4 x 8 GB DDR3, 1600 MHz / PC3-12800, CL10, 1.5 V, non ECC
PCI-e: Dell H310 6Gbps SAS HBA LSI 9211-8i
TrueNAS: SCALE-22.12.2
I am out of ideas now.
I will highly appreciate any suggestions
Thank you.
NugentS
Check the temps on your H310 using the finger test. These cards need airflow or they melt (figuratively, they shit themselves a long time before actually melting)
Also, it is in IT mode isn't it?
Constantin.FF
Temperatures of the H310 seems to be OK.
I believe that the issue is not really from the PCi-e SAS card, because I get the same result as when I am using the motherboard SATA ports
Constantin.FF
I got some progress here.
First I removed the H310 card since it does not look the problem is from it.
Connected the ssds again to the MB.
The change that I did was with the kernel settings, I have added libata.force=1.5G,noncq
24 hours of running together with smart test on every hour - all good so far.
After that just for the test I removed the setting and immediately one ssd failed a smart test.
One more note - I have tried libata.force=noncq or libata.force=1.5G alone, but getting the same errors.
What do you think is the hardware problem?
And just by adding the sata throttling would it solve the system stability?
I have attached some of the error messages I see in the terminal.
Mainly:
  1. I/O error, dev sda
  2. WRITE FPDMA QUEUED
  3. Unaligned write command
Here are some of the links that helped me while looking for solution:
bew
Hey Constantin, could you explain how you added t hese kernel parameters?
Constantin.FF
here is the command I use so that it is persistent:
midclt call system.advanced.update '{ "kernel_extra_options": "libata.force=noncq" }'
  • Like
Reactions: bew
