Market Guru
- Aug 10, 2014
Hello Community,
I hope this isn't annoying since these type of threads pop up regularly. Well here it goes:
I still haven't decided how to incorporate FreeNAS into my network setup (presented in another thread). I would start with it first and then its easier to follow guides (ex. OpenVPN by another member here).
My goal with FreeNAS would be:
1. Create Redundancy then move all my data currently sitting scattered around multiple drives into FreeNAS
2. FreeNAS will service multiple connections to my Workstation, AW 18 Laptop, Business Laptop and around the home (media: movies, videos, and music).
3. Follow OpenVPN Guide to build ownCloud so specific data can be shared, modified, uploaded to my FreeNAS outside of my WAN
Initially I was concerned about the network transfer rate been limited by common interfaces (Gigabit Ethernet) and would like to pursue 10GgE switches I quickly realize the price of these switches are currently prohibitive. (Switches $1200+) Also, it will only benefit local access times. Internet connection with only 350Mbps (max 43MB/s down and up).
Componenets in questions:
Supermicro Server Boards
X10SAE vs X10SLH-F
Without using LSI SAS9300 8i HBA, will I be able to use the onboard SATA3 to make my zpool?
Components Selected so far for FreeNAS:
CPU E3 - 1276 V3 I will be using it for transcoding and would you recommend something else?
RAM 32GB of Crucial (voltage not sure yet)
HDD: 8 x 3TB WD Red NAS Drives (doing raidz2 with 2 vdevs----vdev 1: 2+2, vdev 2: 2+2)
Please comment if this is optimal HDD setup:
My understanding is: total for raidz2 is 4, 6, 10 so without the parity 2, 4, 8 usable space multiply by drive capacity. My setup should give me vdev 1 6TB and vdev2 6TB.
Throughput and IOPS are they optimized like this?
Thank you.
X10SAE vs X10SLH-F
Thank you.
