Help with Smart errors
s25a
I need your help as I have a broken disk and want to understand what happened here.
First of all - I do a regular extended Smart testing on my disks. And then Send an email report. The scrips I use are hosed here: https://github.com/Spearfoot/FreeNAS-scripts/blob/master/smart_report.sh
The output of this last night was: (Just for the first 3 disks) are shown below. So i have several questions and maybe someone can help as I am really confused.
1) The error disk is ada1...Looking at the at the overall status report however everything's fine. Looking in the detailed section of ada1 it's also fine - on a first view.
It says no errors logged but looking at the CRC_Error_Count - it has more than 6K. So I guess this means the SDD is almost broken right?
If so - I should exchange this immediately I guess. It is a mirrored Volume so I guess I should simply shutdown, exchange and replace the disk (in the WEB GUI). Sorry for stupid question I had never this case before. The good thing everythings backuped so even if somethings going wrong it would not be a disaster.
2) Coming to this script - I am not sure but I think lot of people use this here. My question is...There should be a clear message in the header that one disk is broken. As I do not fully understand the script can someone help me to understand better.
Maybe everything is right and I just misunderstood the parameters.
3) What I also see in disk 3 is: "Status aborted by host". What does that mean?
Thanks a lot for help and support
S
########## SMART status report summary for all drives on server NAS ##########
|Device|Serial			|Temp|Power|Start|Spin |ReAlloc|Current|Offline |Seek  |Total	 |High  |Command|Last|
|	  |Number			|	|On   |Stop |Retry|Sectors|Pending|Uncorrec|Errors|Seeks	 |Fly   |Timeout|Test|
|	  |				  |	|Hours|Count|Count|	   |Sectors|Sectors |	  |		  |Writes|Count  |Age |
|ada0  |S252NXAG820276K   | 34 |24303|	 |	 |	  0|	   |		|   N/A|	   N/A|   N/A|	N/A|   1|
|ada1  |S252NCAGA00376M   | 34 |23966|	 |	 |	  0|	   |		|   N/A|	   N/A|   N/A|	N/A|   1|
|ada2  |WD-WCC4E4AH9899   | 29 |13896| 4797|	0|	  0|	  0|	   0|   N/A|	   N/A|   N/A|	N/A|   1|
|ada3 ?|WD-WCC4E1XUF2Z4   | 29 |13879| 4225|	0|	  0|	  0|	   0|   N/A|	   N/A|   N/A|	N/A|  1|
|ada4 ?|WD-WCC4E5NF9F5F   | 28 |13892| 4860|	0|	  0|	  0|	   0|   N/A|	   N/A|   N/A|	N/A|  1|
|ada5 ?|WD-WCC4E4RXR2E0   | 28 |13883| 4178|	0|	  0|	  0|	   0|   N/A|	   N/A|   N/A|	N/A|  1|
########## SMART status report for ada0 drive (Samsung based SSDs: S252NXAG820276K) ##########
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  9 Power_On_Hours		  0x0032   095   095   000	Old_age   Always	   -	   24303
12 Power_Cycle_Count	   0x0032   099   099   000	Old_age   Always	   -	   200
177 Wear_Leveling_Count	 0x0013   099   099   000	Pre-fail  Always	   -	   14
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010	Pre-fail  Always	   -	   0
181 Program_Fail_Cnt_Total  0x0032   100   100   010	Old_age   Always	   -	   0
182 Erase_Fail_Count_Total  0x0032   100   100   010	Old_age   Always	   -	   0
183 Runtime_Bad_Block	   0x0013   100   100   010	Pre-fail  Always	   -	   0
187 Uncorrectable_Error_Cnt 0x0032   100   100   000	Old_age   Always	   -	   0
190 Airflow_Temperature_Cel 0x0032   066   045   000	Old_age   Always	   -	   34
195 ECC_Error_Rate		  0x001a   200   200   000	Old_age   Always	   -	   0
199 CRC_Error_Count		 0x003e   099   099   000	Old_age   Always	   -	   1
235 POR_Recovery_Count	  0x0012   099   099   000	Old_age   Always	   -	   156
241 Total_LBAs_Written	  0x0032   099   099   000	Old_age   Always	   -	   13190459927
No Errors Logged
Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
Extended offline	Completed without error	   00%	 24290		 -
########## SMART status report for ada1 drive (Samsung based SSDs: S252NCAGA00376M) ##########
  9 Power_On_Hours		  0x0032   095   095   000	Old_age   Always	   -	   23966
12 Power_Cycle_Count	   0x0032   099   099   000	Old_age   Always	   -	   197
177 Wear_Leveling_Count	 0x0013   099   099   000	Pre-fail  Always	   -	   13
190 Airflow_Temperature_Cel 0x0032   066   046   000	Old_age   Always	   -	   34
199 CRC_Error_Count		 0x003e   093   093   000	Old_age   Always	   -	   6076
235 POR_Recovery_Count	  0x0012   099   099   000	Old_age   Always	   -	   152
241 Total_LBAs_Written	  0x0032   099   099   000	Old_age   Always	   -	   12669998984
No Errors Logged
Extended offline	Interrupted (host reset)	  00%	 23952		 -
########## SMART status report for ada2 drive (Western Digital Red: WD-WCC4E4AH9899) ##########
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   183   179   021	Pre-fail  Always	   -	   7841
  4 Start_Stop_Count		0x0032   096   096   000	Old_age   Always	   -	   4797
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   081   081   000	Old_age   Always	   -	   13896
10 Spin_Retry_Count		0x0032   100   100   000	Old_age   Always	   -	   0
11 Calibration_Retry_Count 0x0032   100   100   000	Old_age   Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   123
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   50
193 Load_Cycle_Count		0x0032   197   197   000	Old_age   Always	   -	   11205
194 Temperature_Celsius	 0x0022   123   099   000	Old_age   Always	   -	   29
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   100   253   000	Old_age   Offline	  -	   0
No Errors Logged
Extended offline	Aborted by host			   90%	 13883		 -
m0nkey_
These are data transmission errors. Might be an idea to replace the cable first.
Since it's a 3rd party script, suggest you open an issue on their GitHub page.
The SMART test was aborted because either the test was cancelled or the system was rebooted.
s25a
thanks a lot for your answer. I exchanged the cable as suggested and now the repeating CRC errors which I could in the shell are gone :smile:
However I still see the errors in the smart overview. I am not sure if this is updated after a new test. I just want to be sure that no further CRCs occur and therefore it would make sense to have a 0 there and then check after a few hours if it is still 0. Is thatz possible?
Thanks S
UDMA_CRC errors attribute doesn't reset, as long as it doesn't keep increasing problem is solved.
