James Snell
 - Jul 25, 2013
My FreeNAS rig is installed to two USB flash drives in a mirror RAID. I've run on this for several months and since the beginning there's been this error message about a corrupt root volume and yet it seems to have no effect. I'd prefer to fix the damage, any tips would be most welcome.
Here's the relevant output from
 zpool status -v:Code:
pool: freenas-boot state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 1.21M in 0h2m with 11 errors on Mon Feb 20 03:47:43 2017 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 da0p2 ONLINE 0 0 0 da1p2 ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: freenas-boot/ROOT/9.10.2-U2@2017-01-15-16:53:30:/usr/local/www/data/docs/_images/iperf.png freenas-boot/ROOT/9.10.2-U2@2017-01-15-16:53:30:/usr/local/lib/libiconv.so.2.5.1 freenas-boot/ROOT/9.10.2-U2@2017-01-15-16:53:30:/usr/local/lib/python2.7/site-packages/bsd/acl.so freenas-boot/ROOT/9.10.2-U2@2017-01-15-16:53:30:/usr/local/www/data/docs/_images/translate.png freenas-boot/ROOT/9.10.2-U2@2017-01-15-16:53:30:/usr/local/go/pkg/bootstrap/bin/link freenas-boot/ROOT/9.10.2-U2@2017-01-15-16:53:30:/usr/local/go/pkg/tool/freebsd_amd64/compile freenas-boot/ROOT/9.10.2-U1:/usr/local/lib/python2.7/nntplib.pyc freenas-boot/ROOT/9.10.2-U1:/usr/local/lib/python2.7/bsddb/test/test_dbenv.pyc freenas-boot/ROOT/9.10.2-U1:/var/db/pkg/local.sqlite freenas-boot/ROOT/9.10.2-U1:<0x209f4>
