Help with Nextcloud setup (SSL)
Loren Zimmer
I’ve followed this tutorial and had next cloud working locally until somewhere around the heading “Let’s Cache”. Now when I try and access the page locally I get this error:
192.168.1.93 sent an invalid response.
Try running Windows Network Diagnostics.
ERR_SSL_PROTOCOL_ERROR
The Apache log shows the following:
[Tue Nov 06 23:16:53.971634 2018] [mpm_prefork:notice] [pid 81295] AH00169: caught SIGTERM, shutting down
[Tue Nov 06 23:16:54.084130 2018] [ssl:warn] [pid 81814] AH01873: Init: Session Cache is not configured [hint: SSLSessionCache]
[Tue Nov 06 23:16:54.135464 2018] [mpm_prefork:notice] [pid 81814] AH00163: Apache/2.4.35 (FreeBSD) OpenSSL/1.0.2o-freebsd PHP/7.1.22 configured -- resuming normal operations
[Tue Nov 06 23:16:54.135499 2018] [core:notice] [pid 81814] AH00094: Command line: '/usr/local/sbin/httpd -D NOHTTPACCEPT'
I googled Init: Session Cache is not configured and found a suggestion to uncomment another line in the httpd.conf file which I did but without any success. Does anyone have any recommendations as to the next step I should take to try and get this working?
Thank you
Loren
Loren Zimmer
I haven't, but I also have just made a little progress in narrowing down the problem tonight. I have a feeling that its a certificate error. When I run this command:
certbot certonly --webroot -w /usr/local/www/apache24/data/nextcloud -d YOURSITE.COM
This is the error I get:
IMPORTANT NOTES:
 - The following errors were reported by the server:
   Domain: zimmvpn2.ddns.net
   Type:   unauthorized
   Detail: Invalid response from
   http://zimmvpn2.ddns.net/.well-known/acme-challenge/FtRmYOYG6PWcQztD1DIWUHVjIsjyS94PWzk4SLbymoc:
   "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML
   2.0//EN\">\n<html><head>\n<title>404 Not
   Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
   To fix these errors, please make sure that your domain name was
   entered correctly and the DNS A/AAAA record(s) for that domain
   contain(s) the right IP address.
No, that isn't a certificate error; it means that certbot is putting the challenge file in the wrong place for Let's Encrypt to find it--or, in the alternative, Let's Encrypt isn't connecting to the right server in the first place.
Loren Zimmer
Thank you!
Where do I find where the config for Let's Encrypt or what server it's connecting to?
Loren Zimmer
I've noticed after going through the tutorial that I'm not able to get to next cloud by simply entering the jail IP but I have to add /nextcloud to view the web page. Is this an indicator that there is something wrong with my configuration?
Loren Zimmer
@danb35 you were right a bunch of the questions that I asked were in the tutorial thread. I found a couple of mistakes that I had made and decided to recreate the jail. Now I've hit an error that I couldn't find in the tutorial thread. When I restart apache24 this is the error I get:
httpd: Syntax error on line 548 of /usr/local/etc/apache24/httpd.conf: Syntax error on line 21 of /usr/local/etc/apache24/Includes/myurl.net.conf: /usr/local/etc/apache24/Includes/myurl.net.conf:21: <VirtualHost> was not closed.
Here is the conf file:
<VirtualHost *:80>
DocumentRoot "/usr/local/www/apache24/data/nextcloud"
ServerName myurl.net
RewriteEngine on
RewriteCond %{SERVER_NAME} =myurl.net
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
#ErrorLog ${APACHE_LOG_DIR}/error.log
#CustomLog ${APACHE_LOG_DIR}/access.log combined
<Directory /usr/local/www/apache24/data/nextcloud/>
Options +FollowSymlinks
AllowOverride All
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /usr/local/www/apache24/data/nextcloud
SetEnv HTTP_HOME /usr/local/www/apache24/data/nextcloud
Satisfy Any
</Directory>
</VirtualHost>
<VirtualHost *:443>
  ServerAdmin myemail
  DirectoryIndex index.php
  DocumentRoot /usr/local/www/apache24/data/nextcloud
  SSLCertificateFile /usr/local/etc/letsencrypt/live/myurl.net/fullchain.pem
  SSLCertificateKeyFile /usr/local/etc/letsencrypt/live/myurl.net/privkey.pem
  SSLEngine on
  # Intermediate configuration, tweak to your needs
  SSLProtocol  all -SSLv2 -SSLv3
  SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
  SSLHonorCipherOrder  on
  SSLCompression  off
  SSLOptions +StrictRequire
  <Directory /usr/local/www/apache24/data/nextcloud>
  AllowOverride all
  </Directory>
Any help is greatly appreciated.
