Help with hardware fundamentals
Moved from the Hardware Recommendations Guide discussion thread.
i am new to this, is intel z170 a good choice for a 4TB 20-30 users server?
I suggest actually reading the document whose discussion thread you stumbled upon.
IceBoosteR
A Intel Z170 Board is a consumer mainboard with an chipset, which was designed for performance enthusiast and gamers. This platform is not recommended for a server usage. Look at Intels C232/C236/C422 chipsets instead.
You can use it - yes, but with a more cheaper mainbaord (eg. H170) you would get the same performance. And on both board you usually have no ECC support. So please look at XEON processors and boards etc.
This thread adds nothing to the other one, so I'll just lock it.
