Help with disk expanding
pogy111
I'm new with FreeNAS and I need help with disk expanding. I already read manual but help from some users will be much easier or if someone can give me some easy points on how to extend my total HD capacity? Now I have three disks of 2TB each (actual space is now of 3.8TB, mirroring system). I would like to ad additional three disks of same space (2TB).
I know that is explained everything in manual but it's much easier if someone explain to you wit some steps.
Thanks and best regards.
Luka
pogy111
Someone already explain me to extend pool, but i don't know exactly how to? Any suggestion on how to do that easier?
Thanks!!
gpsguy
Active Member
Please do not cross post.
You posted the same message a day or two ago.
Sent from my phone
pogy111
Ok sorry,
I thought it would be better to start new post. As this is an help part forum.
Bidule0hm
Server Electronics Sorcerer
pogy111
Ok, thanks for so nice answer! And for your information I searched the forum before I asked but I didn't find any question about it. Maybe my fault but no need of such answer! Instead, you could give me a link of that previous question on the forum.
And thanks for help!!
pogy111
Thank you for the link!! I will search now for the info!! And sory for such questions but as i told, I'm new her with just few weeks of experience with FreeNAS!
And thank you for the link!!!
Bidule0hm
pogy111
Sory for such rude answer but i got link after i wrote a msg!!!
pogy111
Hi
I read online manual and now i'am a little bit more informed about it. Just a question if i did understood correctly. If i add volume to the pool i will lost data on disk that I'm adding or on all disks already in the pool? From Manual: "The “Add Volume” button warns that existing data will be cleared. In other words, creating a new volume reformats the selected disks. If your intent is to not overwrite the data on an existing volume, click the “Cancel” button and refer to Import Disk and Import Volume....."
Thnaks,
Best regards
gpsguy
Active Member
DO NOT ADD A VOLUME.
Read over the section of the manual titled "Extend a volume".
Rather than add a volume, you'll pick your existing volume from the drop down box and add your new disks. Be sure to select the correct volume layout.
Sent from my phone
pogy111
Thank's
i will do that. It's better ask first than lose data. If i will have some problems can i write to you?
Thanks again!!
gpsguy
Active Member
I'll send you a PM in a few hours.
Sent from my phone
