Steve Kehlet
- Jan 22, 2014
Hello, my new FreeNAS system is crashing every other day or so while I'm rsync'ing data onto it. I've tried to do my due diligence (googling, searching through this forum) but could use some help now interpreting the crash logs I have and/or with suggestions on what to try next. We've run memtest86++ several times and it hasn't found any problems.
FreeNAS 9.2.0 RELEASE
CPU: Xeon E3-1230V2
Mobo: ASUS P9D-X
RAM: 2x Kingston 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) ECC Registered Server Memory Model KVR1333D3D4R9SK2/16G
(Updated) RAM: Kingston Technology ValueRAM 32GB Kit of 4 (4 x 8 GB) DDR3 1600MHz PC3 12800 ECC CL11 DIMM with TS Server Workstation Memory KVR16E11K4/32
HBA: LSI SAS 9207-8i
HDs: 6x WD SE WD4000F9YZ
The full dmesg output is available here.
After the first reboot I created a 'syslog' ZFS dataset, and then found this in /var/log/messages after the next reboot:
After the most recent reboot there was nothing in /var/log/messages but I found the following in /data/crash/textdump.tar.last:
and
The full textdump.tar.last is here. I see the backtrace there shows the ethernet interface (igb0). I don't know if/how exactly that's particularly significant (kernel bug?), or if it's just a matter of that's what happened to be running when something bad happened (e.g. hardware problem).
I'm considering pulling the 4 DIMMs and trying them one at a time to try to isolate the crashes to a particular DIMM.
Any better suggestions? Can I provide any more information to be helpful? Thanks so much.
CPU: Xeon E3-1230V2
Mobo: ASUS P9D-X
Jan 19 17:38:35 freenas kernel: Fatal trap 9: general protection fault while in kernel mode Jan 19 17:38:35 freenas kernel: cpuid = 6; apic id = 06 Jan 19 17:38:35 freenas kernel: instruction pointer = 0x20:0xffffffff8089d150 Jan 19 17:38:35 freenas kernel: stack pointer = 0x28:0xffffff88a9c1e1a0 Jan 19 17:38:35 freenas kernel: frame pointer = 0x28:0xffffff88a9c1e1d0 Jan 19 17:38:35 freenas kernel: code segment = base 0x0, limit 0xfffff, type 0x1b Jan 19 17:38:35 freenas kernel: = DPL 0, pres 1, long 1, def32 0, gran 1 Jan 19 17:38:35 freenas kernel: processor eflags = interrupt enabled, resume, IOPL = 0 Jan 19 17:38:35 freenas kernel: current process = 5185 (rsync) Jan 19 17:38:35 freenas kernel: Copyright (c) 1992-2013 The FreeBSD Project. Jan 19 17:38:35 freenas kernel: Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
db:0:kdb.enter.default> bt Tracing pid 12 tid 100057 td 0xfffffe0009649000 igb_txeof() at igb_txeof+0x141/frame 0xffffff885af379e0 igb_msix_que() at igb_msix_que+0x9f/frame 0xffffff885af37a20 intr_event_execute_handlers() at intr_event_execute_handlers+0xfd/frame 0xffffff885af37a50 ithread_loop() at ithread_loop+0x9a/frame 0xffffff885af37aa0 fork_exit() at fork_exit+0x11f/frame 0xffffff885af37af0 fork_trampoline() at fork_trampoline+0xe/frame 0xffffff885af37af0 --- trap 0, rip = 0, rsp = 0xffffff885af37bb0, rbp = 0 ---
and
Fatal trap 9: general protection fault while in kernel mode cpuid = 1; apic id = 01 instruction pointer = 0x20:0xffffffff804a6871 stack pointer = 0x28:0xffffff885af37980 frame pointer = 0x28:0xffffff885af379e0 code segment = base 0x0, limit 0xfffff, type 0x1b = DPL 0, pres 1, long 1, def32 0, gran 1 processor eflags = interrupt enabled, resume, IOPL = 0 current process = 12 (irq266: igb0:que 1)
