Help with degraded pool
Vargan
Hello everyone!
My disks got degraded.
I'm running TrueNAS under Proxmox. I have 2 disks in the pool - zfs stripe. I know this setup is discouraged, but this is what I decided to go with before I have more drives to create proper redundancy.
Here is what happened. I had 2 instances of TrueNAS installed. The pool was detached from one of the instances and attached to the other. Also Only one was running at the end, and the first one was shut down.
All was running fine. At some point the whole Proxmox system got rebooted and both instances was running (which I didn't notice for some time).
One day I needed to access the SMB from my PC and I logged into Truenas.
It appeared that the pool wasn't attached (at that point I didn't know that I have 2 instances running and that I'm logged into the one that was supposed to be shutdown). So I attached the pool and enabled SMB.
All was fine for a bit. Later that day I noticed that I have 2 instances of TrueNAS running and tried shutdown the one I didn't need. At some point during this process 1 drive showed status DEGRADED. And later the 2nd one also got degraded.
I probably also need to mention that I detach the pool from one of the instances
Is there way to restore at least some of the data from those drives?
Any help or advise on what can be done is greatly appreciated!
Thank you!
This is what zpool status -v says:
zpool status -v
  pool: NAS
 state: DEGRADED
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
  scan: scrub repaired 276K in 04:06:02 with 213 errors on Mon May  8 05:18:25 2023
        NAME                                    STATE     READ WRITE CKSUM
        NAS                                     DEGRADED     0     0     0
          a548546e-b11b-48ce-8683-6a1e7a626358  DEGRADED     0     0   132  too many errors
          a10ae8c7-7298-40ce-9d41-a8a1d5dcf1db  DEGRADED     0     0   132  too many errors
        NAS/ix-applications/releases/nextcloud/volumes/pvc-1e1b3281-f845-48dc-abe7-155e1dce36d5:<0x0>
        NAS/ix-applications/releases/nextcloud/volumes/pvc-287f77af-4fb9-49a7-a9dc-f3511effe4d0:/data/global/pg_control
        NAS/ix-applications/releases/nextcloud/volumes/pvc-287f77af-4fb9-49a7-a9dc-f3511effe4d0:/data/pg_wal/000000010000000000000087
        NAS/ix-applications/releases/nextcloud/volumes/pvc-287f77af-4fb9-49a7-a9dc-f3511effe4d0:/data/postmaster.opts
        /var/db/system/update/update.sqsh
        /mnt/NAS/ix-applications/k3s/server/db/state.db
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/88ebfb0be7779ccb335b3965fdaed77ff919a37d99727d477458e1e2b3ffbbf1
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/c5347baf34de279423a87edd1fce00fc22b243b955425231cde80c6a0a767506
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/22d1704b97827302ffe7ac549ea4c4f9e18eea3f8575a95f9e9e32ddad11e8c8
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/f6721c0e5de1fe3459c42b69d1f7d79dbd4a2fd98eb38d201e922673cd604174
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/d96cfeaa930ba9718513b48c33f345675871d18841504a467d8f103583eef6ab
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/795b33ed1e7be38339b2e35103680b90593e7f82170409843c9a5517803f65ff
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/d1b1b262dea487a33dcbe0d60cafcb35666d7b56c9a82b74324b300007bf5e71
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/bb56285e58440339b017ea861184447a423c1207f8d03c8175dd4c2965070092
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/9bc7ba3cf4e2c28982dcf328f948f96972d07d08643e05fe9a746258812fa38a
        /mnt/NAS/ix-applications/k3s/agent/cri-dockerd/sandbox/6b2b0f820be74bec2e6f94d184fd0dd5d55d6d2b83dbacbf89da19f439afcf39
        NAS/.system/syslog-5a0a2a47cd884dbcbe527966286bfc29:<0x0>
        /var/db/system/syslog-5a0a2a47cd884dbcbe527966286bfc29/log/containerd.log.1
        /var/db/system/syslog-5a0a2a47cd884dbcbe527966286bfc29/log/kube_router.log
        NAS/.system/syslog-5a0a2a47cd884dbcbe527966286bfc29:<0xfb>
        NAS/.system/syslog-5a0a2a47cd884dbcbe527966286bfc29:<0xff>
        /var/db/system/configs-5a0a2a47cd884dbcbe527966286bfc29/TrueNAS-SCALE-22.12.0/20230421.db
        NAS/ix-applications/k3s/kubelet:<0x0>
        NAS/ix-applications/k3s/kubelet:<0x22c>
        NAS/ix-applications/k3s/kubelet:/pods/8cb5f21c-e67d-4752-9112-643f1ab8c0e4/etc-hosts
        NAS/ix-applications/k3s/kubelet:/pods/8cb5f21c-e67d-4752-9112-643f1ab8c0e4/volumes/kubernetes.io~csi/pvc-287f77af-4fb9-49a7-a9dc-f3511effe4d0/vol_data.json
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/zerotier/ci/basic-values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/zerotier/templates/common.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/zerotier/upgrade_strategy
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/enterprise/minio/metadata.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/enterprise/minio/questions.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/enterprise/minio/templates/_minio.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/enterprise/minio/templates/common.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/enterprise/minio/values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/docs/container/command.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/docs/container/envFrom.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/docs/container/termination.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/docs/imagePullSecret.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/sonarr/Chart.lock
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/docs/persistence/README.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/sonarr/item.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/sonarr/questions.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/docs/service/README.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/sonarr/upgrade_strategy
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/sonarr/values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/docs/workload/deployment.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/tailscale/Chart.lock
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/tailscale/Chart.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/tailscale/ci/basic-values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/class/_job.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/class/_service.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/tailscale/templates/_tailscale.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/helpers/_getPortRange.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/helpers/_getSelectedPod.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/lib/certificate/_getData.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/lib/certificate/_validation.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/ix-chart/templates/_helpers.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/ix-chart/templates/_volumes.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/ix-chart/templates/_workload.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/lib/configmap/_validation.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/ix-chart/templates/service.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/tdarr/metadata.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/lib/container/_command.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/lib/container/_env.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/netdata/.helmignore
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/tdarr/templates/_portal.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/netdata/Chart.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/netdata/README.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/lib/container/_lifecycle.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/tdarr/upgrade_strategy
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/tdarr/values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/terraria/Chart.lock
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/lib/container/_securityContext.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/common/templates/lib/container/_volumeMounts.tpl
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/terraria/app-readme.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/netdata/templates/clusterrolebinding.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/netdata/templates/deployment.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/terraria/ci/vanilla-basic-values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/terraria/item.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/terraria/metadata.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/nextcloud/app-readme.md
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/nextcloud/item.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/nextcloud/questions.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/vaultwarden/ci/admin-values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/vaultwarden/ci/other-user-values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/charts/nextcloud/templates/backup-postgres-config.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/vaultwarden/ci/ws-disabled-values.yaml
        /mnt/NAS/ix-applications/catalogs/github_com_truenas_charts_git_master/library/ix-dev/community/vaultwarden/templates/_portal.tpl
        NAS/ix-applications/docker:<0x0>
        /mnt/NAS/ix-applications/docker/containerd/daemon/io.containerd.metadata.v1.bolt/meta.db
        /mnt/NAS/ix-applications/docker/containers/d10725d15b0226c8a32b6a2149b38e6ae65b00df73d49b3e04b491a74b89cc05/d10725d15b0226c8a32b6a2149b38e6ae65b00df73d49b3e04b491a74b89cc05-json.log
        /mnt/NAS/ix-applications/docker/overlay2/c1292c95f10e1a89cf222194feb8ecc1aab90181cb9a65bddac61558974c92e5/lower
        /mnt/NAS/ix-applications/docker/containers/f6721c0e5de1fe3459c42b69d1f7d79dbd4a2fd98eb38d201e922673cd604174/hosts
        /mnt/NAS/ix-applications/docker/overlay2/e79484c7fcff49a94a5602b55ac3e8fc61fb4e640357d06a80a37151eb0a6d97-init/lower
        /mnt/NAS/ix-applications/docker/containers/992bc0a7166a358447c23ebf53467a0ddd75278a521d695f95af659d4dbd8876/config.v2.json
        /mnt/NAS/ix-applications/docker/overlay2/4585ec12179c93d24f150fce2eef637986fc541e9b63898737440cc6a06286f3-init/lower
        /mnt/NAS/ix-applications/docker/containers/88ebfb0be7779ccb335b3965fdaed77ff919a37d99727d477458e1e2b3ffbbf1/88ebfb0be7779ccb335b3965fdaed77ff919a37d99727d477458e1e2b3ffbbf1-json.log
        /mnt/NAS/ix-applications/docker/containers/f2e60a29184e82ead3bca29d03a990835e8d83b7036ef7b0e92b8217f0d73643/config.v2.json
        /mnt/NAS/ix-applications/docker/containers/f6721c0e5de1fe3459c42b69d1f7d79dbd4a2fd98eb38d201e922673cd604174/f6721c0e5de1fe3459c42b69d1f7d79dbd4a2fd98eb38d201e922673cd604174-json.log
        /mnt/NAS/ix-applications/docker/containers/72dbc601ca64e5ed4773376c81f6ab2d16721b0e5a3edbd69114637d58e50abb/config.v2.json
        /mnt/NAS/ix-applications/docker/containers/37f9c11933e913559d9c3da57069e42cdd958172de2e24d4957e2fef06fb42a5/config.v2.json
        /mnt/NAS/ix-applications/docker/containers/d10725d15b0226c8a32b6a2149b38e6ae65b00df73d49b3e04b491a74b89cc05/hosts
        /mnt/NAS/ix-applications/docker/containers/ade96b7c054d298269fd9406d7f2420ab36c7f4e1131ce2d5a4b178e37d1da7c/ade96b7c054d298269fd9406d7f2420ab36c7f4e1131ce2d5a4b178e37d1da7c-json.log
        /mnt/NAS/ix-applications/docker/containers/fb362ca4dce1397c1b99f6f56291b5a350c7c464794fdaa83d16883e174201bf/config.v2.json
        /mnt/NAS/ix-applications/docker/containers/992bc0a7166a358447c23ebf53467a0ddd75278a521d695f95af659d4dbd8876/hosts
        /mnt/NAS/ix-applications/docker/containers/f2703d7a6fa4563a22207bc3b0e310b5c2061f4b186cd337e59f45691f553a49/f2703d7a6fa4563a22207bc3b0e310b5c2061f4b186cd337e59f45691f553a49-json.log
        /mnt/NAS/ix-applications/docker/containers/d10725d15b0226c8a32b6a2149b38e6ae65b00df73d49b3e04b491a74b89cc05/config.v2.json
        /mnt/NAS/ix-applications/docker/containers/cbd84ccb9175663c3779d06c779c86fbab62dab08c0d89a5b53574206bdfa8a1/config.v2.json
        /mnt/NAS/ix-applications/docker/containers/fb362ca4dce1397c1b99f6f56291b5a350c7c464794fdaa83d16883e174201bf/hostconfig.json
        /mnt/NAS/ix-applications/docker/containers/37f9c11933e913559d9c3da57069e42cdd958172de2e24d4957e2fef06fb42a5/37f9c11933e913559d9c3da57069e42cdd958172de2e24d4957e2fef06fb42a5-json.log
        /mnt/NAS/ix-applications/docker/containers/cbd84ccb9175663c3779d06c779c86fbab62dab08c0d89a5b53574206bdfa8a1/hostconfig.json
        /mnt/NAS/ix-applications/docker/containers/1fcf259d342c2e3c5e72bd215553e7e64f69845280ac843e28d58518ed54a094/hosts
        /mnt/NAS/ix-applications/docker/containers/49870cd8e86d9f5ad782240e5ff82b25ac861949cbdbc82833d6402e9cd5cbe5/.tmp-config.v2.json489740597
        /mnt/NAS/ix-applications/docker/containers/88ebfb0be7779ccb335b3965fdaed77ff919a37d99727d477458e1e2b3ffbbf1/hostconfig.json
        /mnt/NAS/ix-applications/docker/containers/d96cfeaa930ba9718513b48c33f345675871d18841504a467d8f103583eef6ab/hosts
        /mnt/NAS/ix-applications/docker/containers/a7a969a38c71abe657c761c9c7695cabfebd74dc9954430776493221875387f0/a7a969a38c71abe657c761c9c7695cabfebd74dc9954430776493221875387f0-json.log
        /mnt/NAS/ix-applications/docker/overlay2/21818f699cd13e21980d63826d69c1791d76066da607a95d57514fde12bedd6b/lower
        /mnt/NAS/ix-applications/docker/containers/f6721c0e5de1fe3459c42b69d1f7d79dbd4a2fd98eb38d201e922673cd604174/hostconfig.json
        /mnt/NAS/ix-applications/docker/overlay2/03d10c20593b4a310d155674aa73d437e62ab6b18f916f280319382b1b717f21-init
        NAS/ix-applications/docker:<0x212f6>
        /mnt/NAS/ix-applications/docker/overlay2/c1292c95f10e1a89cf222194feb8ecc1aab90181cb9a65bddac61558974c92e5-init/lower
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:13 with 0 errors on Fri May 19 03:45:15 2023
          sda3      ONLINE       0     0     0
errors: No known data errors
Whatever you can still read from the pool is what you've got... no idea about how much that will be, but looking at the corrupted list, that's all your apps, so probably none of those.
You're running in Proxmox, passing disks into VMs...
3 things to recommend:
1. don't put any data on that system that you don't want to lose.
2. read this if you want to continue to virtualize and not lose your data... it's not negotiable in virtual environments, you must passthrough an entire SATA controller, not individual disks. https://www.truenas.com/community/t...de-to-not-completely-losing-your-data.109256/
3. if you care about the data you're putting on there and have already followed recommendation 2, then make a pool with some level of redundancy so you have a way to recover from corruption (even if it shouldn't really happen to you if you set up the hardware correctly and do your scrubs and SMART tests).
Vargan
Thank you for reply
Thank you for reply.
I was planning to get SATA controller and passthrough the whole thing, but now I think I'd better get a dedicated machine for TrueNAS
Learned it the hard way.
