In case of errors like these:
[EINVAL] kubernetes_update.force: Missing '/mnt/Your_pool_name_here/ix-applications/config.json' configuration file. Specify force to override this and let system re-initialize applications.
[EINVAL] kubernetes_update.force: '/mnt/Your_pool_name_here/ix-applications/config.json' configuration file is an invalid JSON file. Specify force to override this and let system re-initialize applications.
You can also try manually putting valid config.json file into this folder and restart everything to see if it solves the problem
Valid content of this config.json file should look like below:
{"id": 1, "pool": "Your_pool_name_here", "cluster_cidr": "172.16.0.0/16", "service_cidr": "172.17.0.0/16", "cluster_dns_ip": "172.17.0.10", "route_v4_interface": "Your_network_interface_name_here", "route_v4_gateway": "Your_router_IP_here", "route_v6_interface": null, "route_v6_gateway": null, "node_ip": "0.0.0.0", "configure_gpus": true, "servicelb": true, "passthrough_mode": false, "metrics_server": false, "dataset": "Your_pool_name_here/ix-applications"}
Make sure You substitute these 3 phrases with correct values:
"Your_pool_name_here" - name of the data pool
"Your_network_interface_name_here" which should be like enp2s12, obtainable with command: ip route
"Your_router_IP_here" which should be like 192.168.1.20, obtainable with command: ip route
Also You may need to set different Id than 1 if the problem happens to a disk with different ID
After substitution of these 3 phrases, You can run this command
cat > /mnt/Your_pool_name_here/ix-applications/config.json
paste the valid config.json content
Ctrl + D to exit
