victorbrca
- Oct 1, 2013
Hey everyone, I'm running FreeNAS 9.1.1 for quite a few years, and one of my drives finally failed. I think it's toast, but I wanted to see if there's a way to attempt to fix it so I can recover some files.
Some background on my setup. Because of budget at the time of the build, I spent most of my money on the PC that I run my FreeNAS, and not on the drives. I have 2x pools; one has 5 drives with different sizes and no parity, which is where I save my files; and another pool (called Backup) with 2x WD greens that are mirrored. I have rsync jobs that copy my files to this Backup pool.
All my really important files were backed up, but I found out that some of the jobs for the not so important files weren't running for quite a while, and I would like to attempt to get these files back.
After resolving this issue my plan is to install FreeNAS 11, import the backup pool, and then setup a new RAIDZ1 with 3 new WD reds that I just got.
Getting to the point... here's the error message I started to see:
Output from `smartctl` with read failure
And I also ran 'badblocks' non-destructive, and it did find a high number of badblocks. I can't find where I saved the output, so I'm running again and will post here.
Additional system info:
Thanks for any help.
Jun 13 14:10:33 FreeNAS kernel: (ada2:ahcich2:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC ) Jun 13 14:10:33 FreeNAS kernel: (ada2:ahcich2:0:0:0): RES: 41 40 ac 00 40 40 00 00 00 00 00 Jun 13 14:10:33 FreeNAS kernel: (ada2:ahcich2:0:0:0): Retrying command Jun 13 14:10:33 FreeNAS kernel: (ada2:ahcich2:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 80 00 40 40 00 00 00 01 00 00 Jun 13 14:10:33 FreeNAS kernel: (ada2:ahcich2:0:0:0): CAM status: ATA Status Error
# smartctl -a /dev/ada2 smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Blue Serial ATA Device Model: WDC WD5000AAKS-22TMA0 Serial Number: WD-WCAPW4102538 LU WWN Device Id: 5 0014ee 255bcb94d Firmware Version: 12.01C01 User Capacity: 500,107,862,016 bytes [500 GB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: ATA/ATAPI-7 (minor revision not indicated) Local Time is: Wed Jun 13 14:30:55 2018 EDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (12000) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 150) minutes. Conveyance self-test routine recommended polling time: ( 6) minutes. SCT capabilities: (0x303f) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 200 200 051 Pre-fail Always - 284 3 Spin_Up_Time 0x0003 177 168 021 Pre-fail Always - 6116 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 520 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x000e 200 200 051 Old_age Always - 0 9 Power_On_Hours 0x0032 019 019 000 Old_age Always - 59419 10 Spin_Retry_Count 0x0012 100 100 051 Old_age Always - 0 11 Calibration_Retry_Count 0x0012 100 100 051 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 466 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 380 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 520 194 Temperature_Celsius 0x0022 111 090 000 Old_age Always - 39 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0012 194 194 000 Old_age Always - 489 198 Offline_Uncorrectable 0x0010 195 195 000 Old_age Offline - 455 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 197 197 051 Old_age Offline - 248 SMART Error Log Version: 1 ATA Error Count: 3473 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 3473 occurred at disk power-on lifetime: 59418 hours (2475 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 80 5c 38 40 Error: UNC at LBA = 0x00385c80 = 3693696 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 00 80 5c 38 3a 08 00:04:12.832 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:10.601 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:08.373 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:06.433 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:04.485 READ DMA EXT Error 3472 occurred at disk power-on lifetime: 59418 hours (2475 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 80 5c 38 40 Error: UNC at LBA = 0x00385c80 = 3693696 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 00 80 5c 38 3a 08 00:04:10.601 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:08.373 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:06.433 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:04.485 READ DMA EXT 2f 00 01 10 00 00 00 08 00:04:04.482 READ LOG EXT Error 3471 occurred at disk power-on lifetime: 59418 hours (2475 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 80 5c 38 40 Error: UNC at LBA = 0x00385c80 = 3693696 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 00 80 5c 38 3a 08 00:04:08.373 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:06.433 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:04.485 READ DMA EXT 2f 00 01 10 00 00 00 08 00:04:04.482 READ LOG EXT 60 00 00 80 5a 38 3a 08 00:04:02.387 READ FPDMA QUEUED Error 3470 occurred at disk power-on lifetime: 59418 hours (2475 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 80 5c 38 40 Error: UNC at LBA = 0x00385c80 = 3693696 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 00 80 5c 38 3a 08 00:04:06.433 READ DMA EXT 25 00 00 80 5c 38 3a 08 00:04:04.485 READ DMA EXT 2f 00 01 10 00 00 00 08 00:04:04.482 READ LOG EXT 60 00 00 80 5a 38 3a 08 00:04:02.387 READ FPDMA QUEUED 2f 00 01 10 00 00 00 08 00:04:02.385 READ LOG EXT Error 3469 occurred at disk power-on lifetime: 59418 hours (2475 days + 18 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 80 5c 38 40 Error: UNC at LBA = 0x00385c80 = 3693696 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 25 00 00 80 5c 38 3a 08 00:04:04.485 READ DMA EXT 2f 00 01 10 00 00 00 08 00:04:04.482 READ LOG EXT 60 00 00 80 5a 38 3a 08 00:04:02.387 READ FPDMA QUEUED 2f 00 01 10 00 00 00 08 00:04:02.385 READ LOG EXT 60 00 00 80 5a 38 3a 08 00:03:59.898 READ FPDMA QUEUED SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 59311 62207 SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
# camcontrol devlist <WDC WD30EZRX-00D8PB0 80.00A80> at scbus0 target 0 lun 0 (ada0,pass0) <WDC WD30EZRX-00DC0B0 80.00A80> at scbus1 target 0 lun 0 (ada1,pass1) <WDC WD5000AAKS-22TMA0 12.01C01> at scbus2 target 0 lun 0 (ada2,pass2) <WDC WD30EZRX-00DC0B0 80.00A80> at scbus3 target 0 lun 0 (ada3,pass3) <WDC WD10EADS-00L5B1 01.01A01> at scbus4 target 0 lun 0 (ada4,pass4) <WDC WD20EARS-00MVWB0 50.0AB50> at scbus5 target 0 lun 0 (ada5,pass5) <Kingmax USB2.0 FlashDisk 0.00> at scbus6 target 0 lun 0 (pass6,da0)
# zpool status -v pool: Backup state: ONLINE scan: scrub repaired 0 in 2h8m with 0 errors on Sun Jun 10 02:08:43 2018 config: NAME STATE READ WRITE CKSUM Backup ONLINE 0 0 0 gptid/2bcb9274-74ba-11e3-a683-94de806dfb29 ONLINE 0 0 0 gptid/2cc595fd-74ba-11e3-a683-94de806dfb29 ONLINE 0 0 0 errors: No known data errors
# /sbin/ifconfig | grep media media: Ethernet autoselect (1000baseT <full-duplex>)
