trying to make a web server
i would like some help as i'm 120% lost
i get this :?
^ that is working now
but this is not
don't know what is happening would like some help
i get this :?
jail# pkg_add -r nginx
Fetching ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.2-release/Late st/nginx.tbz... Done. ln: /usr/local/www/nginx: No such file or directory pkg_add: command 'if [ ! -d /usr/local/www/nginx/ ] ; then ln -fs /usr/local/www /nginx-dist /usr/local/www/nginx; fi' failed pkg_add: warning: package 'nginx-0.8.54' requires 'pcre-8.12', but 'pcre-8.30_2' is installed
but this is not
jail# echo "nginx_enable=YES" >> /etc/rc.conf
jail# service nginx start
Performing sanity check on nginx configuration:
/libexec/ld-elf.so.1: Shared object "libpcre.so.0" not found, required by "nginx
Starting nginx.
/usr/local/etc/rc.d/nginx: WARNING: failed to start nginx
jail#
