compufreak
- Aug 27, 2018
Hi I am brand new to FreeNAS, and basically know the absolute minimum. All went well until about 3 a week ago when something happened to one of my HDD's. Not sure how to check and I get the following error on then when I expand my Volumes -- MainDataStore 0 (error) - Error getting available space? Status = Unknown - All my SMB shares are missing and I have about 6TB of Data on those drives? Does this mean I have lost all my data?
I also getting Critical alert : The volume MainDataStore is UNKNOWN:
I am running
FreeNAS-11.2-BETA1 on da0 - My USB Stick SANDISK 8GB
ASROCK H110M MB
16GB RAM DDR3 1600
Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
4 x 2TB HDD's (2x 2TB WD Green SATA 3Gb/s 64 MB Cache - ada0 & ada2 respectively, and 2x 2TB, SEAGATE Video 3.5-Inch 2 TB 5900 RPM 64 MB Cache, ada1 & ada3, respectively)
I also ran this....
I am totally out of my depth and scared that all my data is lost?
ANY HELP WILL BE APPRECIATED...
Tx
I am running
ASROCK H110M MB
16GB RAM DDR3 1600
I also ran this....
[root@FreakFreeNas ~]#zpool status -v
pool: freenas-boot state: ONLINE scan: scrub repaired 0 in 0 days 00:03:19 with 0 errors on Thu Aug 23 03:48:19 2018 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors [root@FreakFreeNas ~]#zpool list
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALT H ALTROOT freenas-boot 7.19G 1.70G 5.49G - - - 23% 1.00x ONLIN E -
Tx
