Help removing stuck Plugin (Crashplan)
mjk79
Hi Guys,
I have a slight problem that I've been working on for a while and can't seem to find a resolution for. One of my plugins that I decided not to use and remove is stuck and won't delete. (Crashplan)
When i try to delete it, i get this error.
Delete plugin
Request Method:	POST
Request URL:	http://192.168.1.35/admin/plugins/plugins/delete/13/
Software Version:	FreeNAS-11.1-U4 (89e3d93bc)
Exception Type:	MiddlewareError
Exception Value:
[MiddlewareError: jail not found]
Exception Location:	./freenasUI/plugins/models.py in _do_delete, line 165
Server time:	Sun, 14 Oct 2018 11:08:18 -0600
Traceback
Environment:
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
  42.			 response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
  249.			 response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
  178.			 response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
  162.		 return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
  23.				 return view_func(request, *args, **kwargs)
File "./freenasUI/freeadmin/options.py" in wrapper
  210.				 return self._admin.admin_view(view)(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/utils/decorators.py" in _wrapped_view
  149.					 response = view_func(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/views/decorators/cache.py" in _wrapped_view_func
  57.		 response = view_func(request, *args, **kwargs)
File "./freenasUI/freeadmin/site.py" in inner
  142.			 return view(request, *args, **kwargs)
File "./freenasUI/freeadmin/options.py" in delete
  832.				 mf.delete(events=events)
File "./freenasUI/plugins/forms.py" in delete
  75.		 super(PluginsForm, self).delete(request=request, events=events)
File "./freenasUI/common/forms.py" in delete
  142.		 self.instance.delete(**kwargs)
File "./freenasUI/plugins/models.py" in delete
  189.				 self._do_delete(force=force)
File "./freenasUI/plugins/models.py" in _do_delete
  165.			 raise MiddlewareError(_("jail not found"))
Exception Type: MiddlewareError at /admin/plugins/plugins/delete/13/
Exception Value: [MiddlewareError: jail not found]
Request information
GET
No GET data
POST
Variable	Value
__form_id	'dijit_form_Form_3'
FILES
No FILES data
COOKIES
Variable	Value
csrftoken	'********'
sessionid	'e5n1xqs771l9s7ps3jmbh5nurxps1gsh'
fntreeSaveStateCookie	'root%2Croot%2F261%2Croot%2F71%2F73%2Croot%2F91%2Croot%2F91%2F92%2Croot%2F91%2F92%2F93'
META
Variable	Value
I've already removed the jail and storage, but only because this plugin would not delete from the start, so now it's complaining about the jail not being there.
Does anyone know a way i can clear out the plugin via command line?
