Hi Guys,
Need some help please.
I have a folder on a Freenas 9.10 machine. I went to access a file on the machine to find the entire folder was gone. I immediately thought that perhaps someone had deleted it by mistake.
However when I view the .recycle folders for the users the folder it spread between all of the users. If that makes sense. When I click into some of the sub-folders the contents are not as expected. There is lots of tmp files and files with '#3 of ~$MS' in the file name.
Do you have have any idea if this was user error, system crash or perhaps something else? Do you know if there is a way to recover the folders?
Thanks in advance!
Thanks in advance!
