SOLVED Help, My folder dissapeared! ZFS Rename of similarly named folder!
Norlig
I have a folder I had a lot of data on, named for example "ThisFolder".
This was made in windows via the samba share, but I wanted to make it as a Dataset with proper permissions.
I made a Dataset called "ThisFolder0" and set my permissions to that Dataset, plan was to copy the files from "ThisFolder" to "ThisFolder0" then rename "ThisFolder0" to "ThisFolder"
But I did not get that far, as before I even copied any data and renamed the Dataset, I ran "zfs rename <pool>\ThisFolder0 <pool>\ThisFolder1"
Now "ThisFolder" is gone from my pool!
cant see it on the SMB share and cant see if it I open the TrueNas Shell and cd to the <pool>/ and type ls.
The Disk space is unchanged, so I am hoping the files are still there somewhere and can be recovered!
Please help :<
System details:
Version: TrueNAS-12.0-U6
Intel i7 3770K
32GB RAM
Patrick M. Hausen
Output of zfs list please.
Norlig
root@<MyName>-NAS:~ # zfs list
NAME                                                         USED  AVAIL     REFER  MOUNTPOINT
<MyName>-ZFS2-RAID-NAS                                        21.6T  18.5T     11.0T  /mnt/<MyName>-ZFS2-RAID-NAS
<MyName>-ZFS2-RAID-NAS/ThisFolder1                                 205K  18.5T      205K  /mnt/<MyName>-ZFS2-RAID-NAS/ThisFolder1
<MyName>-ZFS2-RAID-NAS/Homedirs                                256G  18.5T      307K  /mnt/<MyName>-ZFS2-RAID-NAS/Homedirs
<MyName>-ZFS2-RAID-NAS/Homedirs/My<LastName>                     205K  18.5T      205K  /mnt/<MyName>-ZFS2-RAID-NAS/Homedirs/My<LastName>
<MyName>-ZFS2-RAID-NAS/Homedirs/<BrotherName>                        222K  18.5T      222K  /mnt/<MyName>-ZFS2-RAID-NAS/Homedirs/<BrotherName>
<MyName>-ZFS2-RAID-NAS/Homedirs/<MyName>                         256G  18.5T      256G  /mnt/<MyName>-ZFS2-RAID-NAS/Homedirs/<MyName>
<MyName>-ZFS2-RAID-NAS/SomeOtherfolder                              10.1T  18.5T     9.89T  /mnt/<MyName>-ZFS2-RAID-NAS/SomeOtherfolder
<MyName>-ZFS2-RAID-NAS/Virtual Machines                        119K  18.5T      119K  -
boot-pool                                                   10.5G  89.3G       96K  none
boot-pool/.system                                            843M  89.3G      774M  legacy
boot-pool/.system/configs-4ac1284ebed34cc7a334eddc730c1ce2    96K  89.3G       96K  legacy
boot-pool/.system/configs-8b63d9632d8a49088a6df6cce90eae99  25.5M  89.3G     25.5M  legacy
boot-pool/.system/cores                                       96K  1024M       96K  legacy
boot-pool/.system/rrd-4ac1284ebed34cc7a334eddc730c1ce2      6.93M  89.3G     6.93M  legacy
boot-pool/.system/rrd-8b63d9632d8a49088a6df6cce90eae99      31.7M  89.3G     31.7M  legacy
boot-pool/.system/samba4                                    1.53M  89.3G      400K  legacy
boot-pool/.system/services                                    96K  89.3G       96K  legacy
boot-pool/.system/syslog-4ac1284ebed34cc7a334eddc730c1ce2    192K  89.3G      192K  legacy
boot-pool/.system/syslog-8b63d9632d8a49088a6df6cce90eae99   2.94M  89.3G     2.94M  legacy
boot-pool/.system/webui                                       96K  89.3G       96K  legacy
boot-pool/ROOT                                              9.61G  89.3G       96K  none
boot-pool/ROOT/12.0-U1.1                                     312K  89.3G     1.36G  /
boot-pool/ROOT/12.0-U2                                       312K  89.3G     1.36G  /
boot-pool/ROOT/12.0-U2.1                                     304K  89.3G     1.36G  /
boot-pool/ROOT/12.0-U3.1                                     308K  89.3G     1.37G  /
boot-pool/ROOT/12.0-U4                                       344K  89.3G     1.39G  /
Patrick M. Hausen
And mount, please ...
Although if I just take a guess you could try zfs umount <MyName>-ZFS2-RAID-NAS/ThisFolder1 and check if your other folder reappears.
Norlig
root@<MyName>-NAS:~ # mount
boot-pool/ROOT/12.0-U6 on / (zfs, local, noatime, nfsv4acls)
devfs on /dev (devfs, local, multilabel)
tmpfs on /etc (tmpfs, local)
tmpfs on /mnt (tmpfs, local)
tmpfs on /var (tmpfs, local)
fdescfs on /dev/fd (fdescfs)
<MyName>-ZFS2-RAID-NAS on /mnt/<MyName>-ZFS2-RAID-NAS (zfs, local, nfsv4acls)
<MyName>-ZFS2-RAID-NAS/ThisFolder1 on /mnt/<MyName>-ZFS2-RAID-NAS/ThisFolder1 (zfs, local, nfsv4acls)
<MyName>-ZFS2-RAID-NAS/Homedirs on /mnt/<MyName>-ZFS2-RAID-NAS/Homedirs (zfs, local, nfsv4acls)
<MyName>-ZFS2-RAID-NAS/TV-Seriar on /mnt/<MyName>-ZFS2-RAID-NAS/SomeOtherFolder (zfs, local, nfsv4acls)
<MyName>-ZFS2-RAID-NAS/Homedirs/<MyName> on /mnt/<MyName>-ZFS2-RAID-NAS/Homedirs/<MyName> (zfs, local, nfsv4acls)
<MyName>-ZFS2-RAID-NAS/Homedirs/<MyBrothersName> on /mnt/<MyName>-ZFS2-RAID-NAS/Homedirs/<MyBrothersName> (zfs, local, nfsv4acls)
<MyName>-ZFS2-RAID-NAS/Homedirs/<MyLastName> on /mnt/<MyName>-ZFS2-RAID-NAS/Homedirs/<MyLastName> (zfs, local, nfsv4acls)
boot-pool/.system on /var/db/system (zfs, local, noatime, nfsv4acls)
boot-pool/.system/cores on /var/db/system/cores (zfs, local, noatime, nfsv4acls)
boot-pool/.system/samba4 on /var/db/system/samba4 (zfs, local, noatime, nfsv4acls)
boot-pool/.system/syslog-8b63d9632d8a49088a6df6cce90eae99 on /var/db/system/syslog-8b63d9632d8a49088a6df6cce90eae99 )
boot-pool/.system/rrd-8b63d9632d8a49088a6df6cce90eae99 on /var/db/system/rrd-8b63d9632d8a49088a6df6cce90eae99 (zfs, )
boot-pool/.system/configs-8b63d9632d8a49088a6df6cce90eae99 on /var/db/system/configs-8b63d9632d8a49088a6df6cce90eae9)
boot-pool/.system/webui on /var/db/system/webui (zfs, local, noatime, nfsv4acls)
boot-pool/.system/services on /var/db/system/services (zfs, local, noatime, nfsv4acls)
ZFS Unmount worked, My files came back in ThisFolder1 for some reason, the ThisFolder did not re-appear, but I atleast have my files back now, thanks alot!
Top Bottom
