Yesterday I made the mistake of installing the firefly daapd plugin and left it running overnight, indexing media. It seems to have put my NAS in an unstable state (possibly a memory leak?).
I cannot log in/do anything via IPMI, all I get is
scrolling over the screen. Pressing CTRL-C or typing 13 and Return (the menu entry for reboot) or blindly typing credentials doesn't help. The SSH login doesn't work either and the Web UI is also not available any longer. Strangely enough I can still mount AFP shares on the NAS. What can I do to reboot cleanly without pulling the plug or doing a hardware reset over IPMI?
Thanks,
Achim
swap_pager_getswapspace(16): failed
Thanks,
Achim
