help! i cant see pools
jinks_one
I am an extreme Newbie. I followed youtube tutes to set up and install my FREENAS system.
Basically it looks as if a couple of my hard drives have failed and have too many bad sectors, namely ada1 and ada2. So i thought i would just replace the drives with new ones.
The PROBLEM: In all of the instructions and youtube tutes the procedure seems to be:
GOTO storage>POOLS... (and then a whole bunch of more steps to take disk offline, replace and then resilver etc).
HOWEVER, this is where im stopped in my tracks... there is no pools in the tree?
i have included screenshots of the critical errors and of the UI which isnt showing me the pools option. If anyone can help direct me, or spot where i am going wrong?
hervon
Please Search Before Posting
Please Provide hardware Setup
It's important to remember that hardware information is extremely important when diagnosing problems so please make sure to include this information if you need help troubleshooting a problem. This includes:
  • Motherboard make and model
  • CPU make and model
  • RAM quantity
  • Hard drives, quantity, model numbers, and RAID configuration, including boot drives
  • Hard disk controllers
  • Network cards
Thanks!
jinks_one
mother board is a Hewlett Packard 1495 (serial:AUD23502WJ)
CPU: i5 2400 @3.10 Ghz
RAM: 8GB
HDD's: 4
ada0 S4Z0KP00, ada1 (faulty) seagate 2tb (1.82) W4Z19JAH, ada2, da0 4C531001540506101165 (sandisk usb- this is the boot disk), da2 (faulty) 20060413092100000.
NIC: Intel(R) 82579LM
hervon
Sadly you failed to specify which version you have. If it's not the case update to the latest version. Hope that helps.
BTW, your hardware does not meet the usual requirements for FreeNAS. Read the forums about it.
Hi @jinks_one, sorry to hear you're having problems.
I know there are some great videos on youtube. I recommend you go to the User Guide here first when you have issues, just because you know the User Guide is quality advice but some youtube videos may be not so great.
Do you happen to know what your pool layout was? Were you using encryption at all? You have two faulty drives, ada1 and da2?
What do you get from the command line when you type zpool status?
jinks_one
im so sorry @hervon :version
FreeNAS-11.1-U7
@PhiloEpisteme i dont think i was using encryption but heres a screen shot of the zpool status from cmd
Heracles
Hey jinks,
Was your pool configured as Raid-Z1 ? If it was and two drives failed at once, then indeed your pool is probably lost. A Raid-Z1 structure can loose only 1 drive, not 2...
This is also why you should always have backups. No single server, even FreeNAS, can ensure never to suffer any problem and never loose any data. All servers can be damaged by fire, just like human error can happen anywhere.
If you loss 2 drives in a Raid-Z1 structure and you have your backups, maybe it will be easier to just build a new pool and restore your backups...
CraigD
Repairing a damaged pool is challenging, I have recently successfully recovered most of a pool for a friend who had a pool "vanish"
ZFS is really really good at protecting data on the right hardware, pool design, with the correct administration
ZFS will even list damaged files
If you pool is unencrypted you have a chance
Everything below is done at your own risk
Firstly I would unplug all the data drives and your boot drives
Install freeNAS on a clean SSD from a USB ISO
Turn the server on to see if it boots correctly if it does power down the server
Reconnect your data pool drives
Turn on the server, attach the pool, then add a share from the GUI (I use FreeNAS-11.0-U2 so cannot help with this process)
Copy the data to a location not in this pool ie another computer
Run a scrub (this should take hours not days)
From shell or SSH client if you can (turn on this service)
zpool status -v
It will display the path and file name of every corrupted file, these are unusable
Plug in anothe drive the same size as the damaged drive, then replace it from the GUI, this should take hours not days
Lastly please read the hardware recommend resource, setup automated smart tests, scrubs, temperature monitoring, and setup Emails. If you do the problem you have had go away, your data will be secure
Hope this helps
Let me know how you get on
Have Fun
