I finally bit the bullet and purchased 2 Solarflare SFN6122F cards and 10G SFP+ Passive Twinax DAC 3M cable. I've installed the cards in my 2 Freenas servers. After rebooting I noticed in the network/interface that the link is down on both machines and the sfxge0 and sfxge1 are both present in that menu. The cable is plugged into the bottom port which I think is sfxge1 port. I've assigned an IP for both cards on a different subnet from my main system.
My Main FreeNAS SuperMicro x9srl-f
ipconfig
My Backup FreeNAS ASROCK E3C226D2I
ipconfig
I'm not sure how to preceed. My goal is to have my replication go over the 10 GIG network.
ipconfig
root@freenasSuper:~ # ifconfig
sfxge0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=ec07ab<RXCSUM,TXCSUM,VLAN_MTU,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWTSO,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:0f:53:0d:f5:14
hwaddr 00:0f:53:0d:f5:14
nd6 options=1<PERFORMNUD>
media: Ethernet 10Gbase-SR <full-duplex,rxpause,txpause> (autoselect)
status: no carrier
sfxge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: 10GIG
ether 00:0f:53:0d:f5:15
hwaddr 00:0f:53:0d:f5:15
inet 192.168.8.48 netmask 0xffffff00 broadcast 192.168.8.255
status: no carrier
em0: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=209b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether 0c:c4:7a:08:68:82
hwaddr 0c:c4:7a:08:68:82
media: Ethernet autoselect
status: no carrier
em1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: Nic
options=2098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC>
ether 0c:c4:7a:08:68:83
hwaddr 0c:c4:7a:08:68:83
inet 192.168.5.48 netmask 0xffffff00 broadcast 192.168.5.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
groups: lo
ether 02:a1:2f:de:fa:00
groups: bridge
member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 24 priority 128 path cost 2000000
member: vnet0.17 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 23 priority 128 path cost 2000
member: vnet0.16 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 22 priority 128 path cost 2000
member: vnet0.15 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 21 priority 128 path cost 2000
member: vnet0.14 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 20 priority 128 path cost 2000
member: vnet0.13 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 19 priority 128 path cost 2000
member: vnet0.12 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 18 priority 128 path cost 2000
member: vnet0.11 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 17 priority 128 path cost 2000
member: vnet0.10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 16 priority 128 path cost 2000
member: vnet0.9 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 15 priority 128 path cost 2000
member: vnet0.8 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 14 priority 128 path cost 2000
member: vnet0.7 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 13 priority 128 path cost 2000
member: vnet0.6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000
member: vnet0.5 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 11 priority 128 path cost 2000
member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: vnet0.3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000
member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000
member: em1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 20000
vnet0.1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: caddy as nic: epair0b
options=8<VLAN_MTU>
ether 0e:c4:7a:9a:61:30
hwaddr 02:d4:d0:00:07:0a
status: active
groups: epair
vnet0.2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: cloud as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:07:4c:d6
hwaddr 02:d4:d0:00:08:0a
status: active
groups: epair
vnet0.3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: duplicati as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:e2:92:b5
hwaddr 02:d4:d0:00:09:0a
status: active
groups: epair
vnet0.4: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: emby as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:79:aa:5f
hwaddr 02:d4:d0:00:0a:0a
status: active
groups: epair
vnet0.5: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: jackett as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:b1:b8:71
hwaddr 02:d4:d0:00:0b:0a
status: active
groups: epair
vnet0.6: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: lazylibrarian as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:fc:6c:97
hwaddr 02:d4:d0:00:0c:0a
status: active
groups: epair
vnet0.7: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: lidarr as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:bf:cd:2e
hwaddr 02:d4:d0:00:0d:0a
status: active
groups: epair
vnet0.8: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: mono_patch as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:af:8f:a1
hwaddr 02:d4:d0:00:0e:0a
status: active
groups: epair
vnet0.9: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: plexpass as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:e4:20:fc
hwaddr 02:d4:d0:00:0f:0a
status: active
groups: epair
vnet0.10: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: radarr as nic: epair0b
options=8<VLAN_MTU>
ether 0e:c4:7a:c1:df:ca
hwaddr 02:d4:d0:00:10:0a
status: active
groups: epair
vnet0.11: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: sabnzbd as nic: epair0b
options=8<VLAN_MTU>
ether 0e:c4:7a:ef:4d:38
hwaddr 02:d4:d0:00:11:0a
status: active
groups: epair
vnet0.12: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: sonarr as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:a5:a4:7e
hwaddr 02:d4:d0:00:12:0a
status: active
groups: epair
vnet0.13: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: tautulli as nic: epair0b
options=8<VLAN_MTU>
ether 0e:c4:7a:46:b0:16
hwaddr 02:d4:d0:00:13:0a
status: active
groups: epair
vnet0.14: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: transmission as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:03:aa:46
hwaddr 02:d4:d0:00:14:0a
status: active
groups: epair
vnet0.15: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: unifi as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:87:00:b4
hwaddr 02:d4:d0:00:15:0a
status: active
groups: epair
vnet0.16: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: urbackup as nic: epair0b
options=8<VLAN_MTU>
ether 0c:c4:7a:4e:7d:7c
hwaddr 02:d4:d0:00:16:0a
status: active
groups: epair
vnet0.17: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: wordpress as nic: epair0b
options=8<VLAN_MTU>
ether 0e:c4:7a:ed:53:08
hwaddr 02:d4:d0:00:17:0a
status: active
groups: epair
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: Attached to Collabora
options=80000<LINKSTATE>
ether 00:bd:5a:9f:fb:00
hwaddr 00:bd:5a:9f:fb:00
status: active
groups: tap
Opened by PID 11162My Backup FreeNAS ASROCK E3C226D2I
ipconfig
ether 00:0f:53:0e:68:b4
hwaddr 00:0f:53:0e:68:b4
status: no carrier
description: 10GIG
ether 00:0f:53:0e:68:b5
hwaddr 00:0f:53:0e:68:b5
inet 192.168.8.50 netmask 0xffffff00 broadcast 192.168.8.255
status: no carrier
igb0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: FreeNAS
options=2400b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWTSO,RXCSUM_IPV6>
ether d0:50:99:5b:da:e4
hwaddr d0:50:99:5b:da:e4
inet 192.168.5.50 netmask 0xffffff00 broadcast 192.168.5.255
status: active
igb1: flags=8c02<BROADCAST,OACTIVE,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=6403bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether d0:50:99:5b:da:e5
hwaddr d0:50:99:5b:da:e5
status: no carrier
groups: lo
ether 02:77:87:c7:01:00
groups: bridge
member: igb0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 3 priority 128 path cost 20000
options=8<VLAN_MTU>
ether d2:50:99:e2:92:b5
hwaddr 02:3c:d0:00:07:0a
status: active
groups: epair
description: associated with jail: plex as nic: epair0b
options=8<VLAN_MTU>
ether d2:50:99:14:fa:09
hwaddr 02:3c:d0:00:08:0a
status: active
groups: epair
dmesg | grep -i '10 G' on both machines returns nothing.I'm not sure how to preceed. My goal is to have my replication go over the 10 GIG network.
