Help fixing permissions on Data set
oleost
Hello.
I have imported a ZFS from that I have used earlier both in Freenas, Nas4free and lastly Ubuntu.
There is some mixed owners of various files inside /mnt/VD01/Storage
So when I example set up a windows share there are some files I cannot delete because of example it says I need to have permisions from "Unix User/1000"
Is there any easy way to get all the permisions like it would have been with an fresh install ? So every user who have access to the windows share can add files, edit and delete?
Artion
You can try to chown recursevly to a FN user you choose, ex. nobody, from the shell as root. Google on the usage of the chown command.
oleost
Okey thanks.
What is consider normal permission / ownership of a shared folder ?
Nobody as owner and permission drwxrwsrwx ?
