Help finding drive / device
allegiance
My console is filling up with read errors siting device "da0", which is the "name" that shows in the View Disks panel on the GUI. I know which bay that drive is in, but when I try to offline the drive, I first type "pool status" and it gives me a list of drives using different names (like
gptid/7c282c51-3158-11e4-aa97-f46d042cc584)
, none of which match up with the drive names in the GUI or the console. Below is my listing. How do I match up the two device names so I know which one to offline? By the way, I am replacing this drive with a larger one, and hope to do so for the rest of the pool to then increase the size of the zpool once done.
[root@freenas] ~# zpool status
pool: Shared
state: ONLINE
status: One or more devices are configured to use a non-native block size.
Expect reduced performance.
action: Replace affected devices with devices that support the
configured block size, or migrate data to a properly configured
pool.
scan: scrub repaired 112K in 515h10m with 0 errors on Sun Aug 9 11:10:55 2015
NAME STATE READ WRITE CKSUM
Shared ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/7c282c51-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7c6483a6-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7c9e6487-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7cd5f10b-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7d0dd7f8-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7d4edb0c-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7db44b5b-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7e060bc3-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7e824187-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/7f2d6225-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0 block size: 512B configured, 4096B native
raidz2-1 ONLINE 0 0 0
gptid/af1cc225-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/aff1afd8-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/b0cc30aa-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/b1a7a1e0-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/b27cccdf-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
gptid/b351f73f-3158-11e4-aa97-f46d042cc584 ONLINE 0 0 0
errors: No known data errors
allegiance
Sorry, by the way, I am running FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
# glabel status
That will give you a conversion from the gptids to the physical disk and partitions. ;)
allegiance
Thank you!
