Looking for some help have ran into the following error when trying to create a Jail via the new UI. Worked ok during 11.1 issue has occured since went to 11.2 U6 (was a fresh install). Any one have any ideas whats going on?
Build
Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz (4 cores)
16GB Ram
2x 8TB Drives
Build
16GB Ram
2x 8TB Drives
report_problem Error: Displaying local fetched releases failed. ('Dataset with path not found',) Error: concurrent.futures.process._RemoteTraceback: """ Traceback (most recent call last): File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker r = call_item.fn(*call_item.args, **call_item.kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 133, in main_worker res = loop.run_until_complete(coro) File "/usr/local/lib/python3.6/asyncio/base_events.py", line 484, in run_until_complete return future.result() File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 93, in _run return await self._call(name, serviceobj, methodobj, params=args, job=job) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 85, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 85, in _call return methodobj(*params) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 668, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 592, in list_resource resource_list = iocage.fetch(list=True, remote=remote, http=True) File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 963, in fetch rel_list = self.list("base") File "/usr/local/lib/python3.6/site-packages/iocage_lib/iocage.py", line 1169, in list quick=quick File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_list.py", line 64, in list_datasets iocage_lib.ioc_json.IOCJson().json_check_default_config() File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 1924, in json_check_default_config self.json_write(default_props, default_json_location) File "/usr/local/lib/python3.6/site-packages/iocage_lib/ioc_json.py", line 431, in json_write if template else None File "libzfs.pyx", line 645, in libzfs.ZFS.get_dataset_by_path libzfs.ZFSException: Dataset with path not found """ The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method result = await self.middleware.call_method(self, message) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1096, in call_method return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1041, in _call return await self._call_worker(name, *args) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1061, in _call_worker return await self.run_in_proc(main_worker, name, args, job) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 995, in run_in_proc return await self.run_in_executor(self.__procpool, method, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 971, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) libzfs.ZFSException: ('Dataset with path not found',)
