Hello from South Dakota - but I'm having really slow transfer issues
Kory
I just joined and I'm in South Dakota, USA.
I'm having really really slow transfer speeds between Win 10 and my FreeNAS box.
Over SMB/CIFS I'm getting around 15 kB/s - 4 MB/s depending on file size. Via SCP I'm getting ~3 MB/s.
I ran the dd test and this system is very very fast (apparently on the order of 2.6 GB/s write and 9.1 GB/s read), see below:
[root@data] /mnt/data/data# dd if=/dev/zero of=tmp.dat bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 41.377843 secs (2594968100 bytes/sec)
[root@data] /mnt/data/data# dd of=/dev/zero if=tmp.dat bs=2048k count=50k
51200+0 records in
51200+0 records out
107374182400 bytes transferred in 11.836208 secs (9071670711 bytes/sec)
Looking at the system panel stuff the CPU load is very small, the disks are barely being used. I have no idea why it is so so slow.
I have also tried to bypass the switch seeing if that was slowing it down and it is not. Everything in-between is 1 Gbps connection.
Any advice? I have attached my debug logs. Thanks in advance!
  • debug-data-20170721164024.tgz
Kory
Yep something is really wrong on the networking side, weird... 21.8 Mbps = 2.7 MB/s
Any ideas where to start looking?
Client connecting to 192.168.1.23, TCP port 5001
TCP window size:  512 KByte (default)
[  3] local 192.168.1.29 port 59913 connected with 192.168.1.23 port 5001
[ ID] Interval	   Transfer	 Bandwidth
[  3]  0.0-10.1 sec  26.1 MBytes  21.8 Mbits/sec
Kory
It pegs out the raspberry pi (limited to 100 Mbps):
TCP window size: 43.8 KByte (default)
[  3] local 192.168.1.20 port 42068 connected with 192.168.1.23 port 5001
[  3]  0.0-10.0 sec   112 MBytes  93.8 Mbits/sec
wblock
Documentation Engineer
Please post a description of your hardware. Ultra-slow network transfers are often an indicator of duplex mismatch, which happened often with old 10/100 switches and should not happen at all with ordinary gigabit switches.
It's difficult to tell what this means. Between what?
Kory
Hello wblock and thank you for responding.
Router is a Netgear Nighthawk X4S R7800 with latest firmware and then connected to an older 1 Gbps switch that is a Linksys branded Cisco SR2024 from 2006 and I have never had slow issues with it. From that switch it connects to another switch in another room that is a TP-LINK TL-SG108. The switch I tried to bypass is the Cisco SR2024 and it made no difference. I have attached the debug up above so I'm not sure what is going on, maybe a Win10 issue? I tried SCP on this same Win10 machine and had similar slow performance.
It is interesting that the RPi will max out, the only other thing I could try is to connect a machine into that same TL-SG108 switch and see if it is faster there with iperf.
Thanks for any hints, tips, or advice you or anyone else may offer.
Jailer
Not strong, but bad
You still haven't answered this yet. Full hardware specs of your server please.
Kory
Hello Jailer, I included the debug logs above and it includes all of that information except for the network hardware which is what he was asking about, but here goes anyhow:
CPU: Intel(R) Pentium(R) CPU G4400 @ 3.30GHz (3312.14-MHz K8-class CPU)
real memory  = 18102616064 (17264 MB)
avail memory = 16482664448 (15719 MB)
em0: <Intel(R) PRO/1000 Network Connection 7.6.1-k> mem 0xf7000000-0xf701ffff irq 16 at device 31.6 on pci0
umass0: <SanDisk Ultra Fit, class 0/0, rev 2.10/1.00, addr 1> on usbus0
ada0: <WDC WD4000FYYZ-01UL1B3 01.01K04> ATA8-ACS SATA 3.x device
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada1: <WDC WD4000FYYZ-01UL1B3 01.01K04> ATA8-ACS SATA 3.x device
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada2: <WDC WD4000FYYZ-01UL1B3 01.01K04> ATA8-ACS SATA 3.x device
ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
ada3: <WDC WD4000FYYZ-01UL1B3 01.01K04> ATA8-ACS SATA 3.x device
ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes)
da0: <SanDisk Ultra Fit 1.00> Removable Direct Access SPC-4 SCSI device
da0: 40.000MB/s transfers
I was able to test it from a machine on that same TP-LINK switch and it too gets slow transfer speeds from Win10. Only about 10-20 MB/s read which is what I'm getting now on the first machine after rebooting router, cable modem, etc.
