amorak
- Nov 4, 2015
Hello everyone,
My freenas server has been slow lately, and I have been getting tgheodd GUI update with errors/pending issues with the HDD at ada1. I ran a long SMART test last night - can anyone help me interpret these results (never really read a SMART report before...)
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-1ER166
Serial Number: REDACTED
LU WWN Device Id: 5 000c50 07954685b
Firmware Version: CC25
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Dec 29 10:15:00 2019 MST
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: ( 89) seconds.
Auto Offline data collection on/off supp ort.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 335) minutes.
Conveyance self-test routine
SCT capabilities: (0x1085) SCT Status supported.
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_ FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 094 086 006 Pre-fail Always - 178744508
3 Spin_Up_Time 0x0003 094 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 730
5 Reallocated_Sector_Ct 0x0033 097 097 010 Pre-fail Always - 3848
7 Seek_Error_Rate 0x000f 084 060 030 Pre-fail Always - 301173674
9 Power_On_Hours 0x0032 058 058 000 Old_age Always - 36867
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 189
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 252
188 Command_Timeout 0x0032 100 081 000 Old_age Always - 19 19 57
189 High_Fly_Writes 0x003a 051 051 000 Old_age Always - 49
190 Airflow_Temperature_Cel 0x0022 072 043 045 Old_age Always In_th e_past 28 (0 129 34 20 0)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 48
193 Load_Cycle_Count 0x0032 096 096 000 Old_age Always - 8765
194 Temperature_Celsius 0x0022 028 057 000 Old_age Always - 28 (0 15 0 0 0)
197 Current_Pending_Sector 0x0012 046 035 000 Old_age Always - 8904
198 Offline_Uncorrectable 0x0010 046 035 000 Old_age Offline - 8904
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 36261h+26m+26.542s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 68559105650
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 300992789820
SMART Error Log Version: 1
ATA Error Count: 251 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 251 occurred at disk power-on lifetime: 36825 hours (1534 days + 9 hours)
When the command that caused the error occurred, the device was active or idle .
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 00 ff ff ff 4f 00 33d+22:50:00.079 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 33d+22:50:00.057 READ LOG EXT
60 00 00 ff ff ff 4f 00 33d+22:49:56.499 READ FPDMA QUEUED
2f 00 01 10 00 00 00 00 33d+22:49:55.623 READ LOG EXT
60 00 00 ff ff ff 4f 00 33d+22:49:52.061 READ FPDMA QUEUED
Error 250 occurred at disk power-on lifetime: 36825 hours (1534 days + 9 hours)
2f 00 01 10 00 00 00 00 33d+22:49:52.039 READ LOG EXT
60 00 00 ff ff ff 4f 00 33d+22:49:48.460 READ FPDMA QUEUED
Error 249 occurred at disk power-on lifetime: 36825 hours (1534 days + 9 hours)
2f 00 01 10 00 00 00 00 33d+22:49:48.013 READ LOG EXT
61 00 20 ff ff ff 4f 00 33d+22:49:43.999 WRITE FPDMA QUEUED
Error 248 occurred at disk power-on lifetime: 36825 hours (1534 days + 9 hours)
60 00 00 ff ff ff 4f 00 33d+22:49:43.995 READ FPDMA QUEUED
60 00 d8 ff ff ff 4f 00 33d+22:49:43.967 READ FPDMA QUEUED
Error 247 occurred at disk power-on lifetime: 36825 hours (1534 days + 9 hours)
40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455
60 00 48 ff ff ff 4f 00 33d+22:49:43.967 READ FPDMA QUEUED
ea 00 00 00 00 00 40 00 33d+22:49:43.949 FLUSH CACHE EXT
Num Test_Description Status Remaining LifeTime(hours) LBA _of_first_error
# 1 Extended offline Completed: read failure 90% 36866 409 2398280
# 2 Short offline Completed without error 00% 34864 -
# 3 Short offline Completed without error 00% 34863 -
# 4 Short offline Completed without error 00% 34862 -
# 5 Short offline Completed without error 00% 34861 -
# 6 Short offline Completed without error 00% 34860 -
# 7 Short offline Completed without error 00% 34859 -
# 8 Short offline Completed without error 00% 34858 -
# 9 Short offline Completed without error 00% 34857 -
#10 Short offline Completed without error 00% 34856 -
#11 Short offline Completed without error 00% 34855 -
#12 Short offline Completed without error 00% 34854 -
#13 Short offline Completed without error 00% 34853 -
#14 Short offline Completed without error 00% 34852 -
#15 Short offline Completed without error 00% 34851 -
#16 Short offline Completed without error 00% 34850 -
#17 Short offline Completed without error 00% 34849 -
#18 Short offline Completed without error 00% 34848 -
#19 Short offline Completed without error 00% 34847 -
#20 Short offline Completed without error 00% 34846 -
#21 Short offline Completed without error 00% 34845 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
