Have I found a bug in FreeNAS v11.1?
When I am hot swapping (Import/Use/Export) a single drive pool I am getting these messages:
freenas savecore: /dev/XXXp1: Operation not permitted
and
freenas syslog-ng[72315]: syslog-ng shutting down; version='3.7.3'
freenas syslog-ng[76101]: syslog-ng starting up; version='3.7.3'
Can someone please tell me why? Anything I need to worry about?
I did not notice any ill effects to the system, and the operations that I performed on the removable pool appeared to complete successfully.
FYI the hot swap bay connects the SATA connector first, and then applies power when the lock key is turned. Then I import the pool from the GUI. After use I export from the GUI, wait for the detach to complete, and turn off the power. After waiting for the drive to spin down I remove and store the drive.
I have provided a section of log for context:
Thanks in advance for any suggestions/advice.
and
Jan 5 01:08:22 freenas ada3 at ahcich5 bus 0 scbus7 target 0 lun 0 Jan 5 01:08:22 freenas ada3: <HGST HDN------------ 83XN> ACS-2 ATA SATA 3.x device Jan 5 01:08:22 freenas ada3: Serial Number -------- Jan 5 01:08:22 freenas ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Jan 5 01:08:22 freenas ada3: Command Queueing enabled Jan 5 01:08:22 freenas ada3: 9537536MB (19532873728 512 byte sectors) [Drive Attached] Jan 5 01:09:34 freenas ZFS: vdev state changed, pool_guid=7-----------------8 vdev_guid=1-----------------73 Jan 5 01:09:37 freenas savecore: /dev/da7p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/da6p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/da5p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/da4p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/da3p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/da2p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/da1p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/da0p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/ada1p1: Operation not permitted Jan 5 01:09:37 freenas savecore: /dev/ada0p1: Operation not permitted Jan 5 01:09:40 freenas syslog-ng[72315]: syslog-ng shutting down; version='3.7.3' Jan 5 01:09:40 freenas syslog-ng[76101]: syslog-ng starting up; version='3.7.3' Jan 5 01:09:42 freenas smbd: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1 [WARNING CAUSED BY A VERY FULL BACKUP POOL AND LEGACY ZFS POOL FORMAT-POOLS COMING FROM v8.3] Jan 5 01:09:58 freenas daemon[3631]: 2018/01/05 01:09:58 [WARN] agent: Check 'service:nas-health' is now warning Jan 5 01:12:02 freenas daemon[3631]: 2018/01/05 01:12:02 [WARN] agent: Check 'service:nas-health' is now warning Jan 5 01:14:05 freenas daemon[3631]: 2018/01/05 01:14:05 [WARN] agent: Check 'service:nas-health' is now warning Jan 5 01:16:09 freenas daemon[3631]: 2018/01/05 01:16:09 [WARN] agent: Check 'service:nas-health' is now warning [WARNING CAUSED BY A VERY FULL BACKUP POOL AND LEGACY ZFS POOL FORMAT-POOLS COMING FROM v8.3] Jan 5 01:17:26 freenas syslog-ng[76101]: syslog-ng shutting down; version='3.7.3' Jan 5 01:17:27 freenas syslog-ng[77876]: syslog-ng starting up; version='3.7.3' Jan 5 01:17:28 freenas savecore: /dev/da7p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/da6p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/da5p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/da4p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/da3p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/da2p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/da1p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/da0p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/ada1p1: Operation not permitted Jan 5 01:17:28 freenas savecore: /dev/ada0p1: Operation not permitted [Drive Detached] Jan 5 01:18:13 freenas daemon[3631]: 2018/01/05 01:18:13 [WARN] agent: Check 'service:nas-health' is now warning Jan 5 01:18:17 freenas ada3 at ahcich5 bus 0 scbus7 target 0 lun 0 Jan 5 01:18:17 freenas ada3: <HGST HDN------------ 83XN> s/n -------- detached Jan 5 01:18:17 freenas (ada3:ahcich5:0:0:0): Periph destroyed
