After having successful experience with freenas 9.2 64 bit using consumer-grade hardware and realizing that data security were my first, second and third priorities; I am now ready to invest into a more decent system.
The sever will be used for basic home applications: torrent, DLNA, sharing files between all portable appliances and central backup… freenas 9.2.x will be configured in ZFS pool, compression and encryption enabled. Will use 2x3Tb HDD from WD Green in RAID1.
I have some open questions regarding hardware selection though as follows:
Motherboard: X10SLH-F vs. X10SLM-F.
It is basically very difficult for me to make a choice. Both board are very similar and retail price is same here in Korea.
Is there a better choice out there?
CPU: Pentium G3220 vs. i3 4130.
I already own the G3220 and is working very nice even with encryption and compression enabled. What performance bump can I expect from the i3?
Memory: 16 or 24 Gb ECC?
Can I save this 100 bucks or not? Will 24 Gb make such a tremendous difference over 16Gb?
Does this build makes sense? Overkill or underkill?
Thank you for your comment.
Best regards
Best regards
