I am looking to build a freenas box for business production so reliability is key. I have a bare chassis Dell PowerEdge 2950 with 2 dual core processors 8gb ram and a PERC5 controller. I am looking to add 6 WD RE4 500GB hard drives for storage I am thinking I would use a 5 disk raid5 array and the 6th disk as a hotspare. I was planning on configuring a hardware raid using the perc5 controller. I was also looking at using a Super Talent PCIe SSD drive for the freenas OS. Does anybody have any thoughts on this configuration will it work will it last I would like to see it run 3 years is this possible?
Thanks for your input,
Matt
Hard Drives
http://www.wdc.com/en/products/products.aspx?id=30
PCIe SSD
http://www.amazon.com/dp/B004YCUQN6/?tag=ozlp-20
Matt
Hard Drives
PCIe SSD
