HardDisk Issue
Avena
Hi everybody !
Someone knows if logs below is a problem on hard drive or sata cable? Or it can be bios wrong config?
Apr 8 01:02:16 freenas ata2: timeout waiting to issue command
Apr 8 01:02:16 freenas ata2: error issuing WRITE_DMA48 command
Apr 8 01:02:16 freenas (ada2:ata2:0:1:0): WRITE_DMA48. ACB: 35 00 08 56 4d 40 47 00 00 00 00 01
Apr 8 01:02:16 freenas (ada2:ata2:0:1:0): CAM status: Command timeout
Apr 8 01:02:16 freenas (ada2:ata2:0:1:0): Retrying command
Sometimes this error is written, but is no alarm.
Chris Moore
Is it always the same disk?
If you can SSH into a terminal window, you can run the command smartctl -x /dev/ada2 to check the status of the drive.
That should give you some output similar to this:
root@freenas[~]# smartctl -x /dev/da3
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68N32N0
Serial Number:    WD-WCC7K1SHEXSP
LU WWN Device Id: 5 0014ee 2652c9583
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Feb 18 19:43:56 2019 CET
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (43380) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 461) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   165   165   021    -    6725
  4 Start_Stop_Count        -O--CK   100   100   000    -    39
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   096   096   000    -    2931
10 Spin_Retry_Count        -O--CK   100   253   000    -    0
11 Calibration_Retry_Count -O--CK   100   253   000    -    0
12 Power_Cycle_Count       -O--CK   100   100   000    -    39
192 Power-Off_Retract_Count -O--CK   200   200   000    -    37
193 Load_Cycle_Count        -O--CK   200   200   000    -    23
194 Temperature_Celsius     -O---K   119   109   000    -    31
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS       1  Device vendor specific log
0xb7       GPL,SL  VS      56  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed without error       00%      2929         -
# 2  Short offline       Completed without error       00%      2911         -
# 3  Short offline       Completed without error       00%      2887         -
# 4  Short offline       Completed without error       00%      2863         -
# 5  Short offline       Completed without error       00%      2839         -
# 6  Short offline       Completed without error       00%      2816         -
# 7  Short offline       Completed without error       00%      2792         -
# 8  Short offline       Completed without error       00%      2768         -
# 9  Short offline       Completed without error       00%      2744         -
#10  Short offline       Completed without error       00%      2721         -
#11  Short offline       Completed without error       00%      2696         -
#12  Short offline       Completed without error       00%      2652         -
#13  Short offline       Completed without error       00%      2628         -
#14  Short offline       Completed without error       00%      2604         -
#15  Short offline       Completed without error       00%      2580         -
#16  Short offline       Completed without error       00%      2556         -
#17  Short offline       Completed without error       00%      2532         -
#18  Short offline       Completed without error       00%      2508         -
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    31 Celsius
Power Cycle Min/Max Temperature:     31/34 Celsius
Lifetime    Min/Max Temperature:     19/41 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/65 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (419)
Index    Estimated Time   Temperature Celsius
420    2019-02-18 11:46    32  *************
...    ..( 29 skipped).    ..  *************
450    2019-02-18 12:16    32  *************
451    2019-02-18 12:17    31  ************
...    ..( 67 skipped).    ..  ************
  41    2019-02-18 13:25    31  ************
  42    2019-02-18 13:26    34  ***************
...    ..( 77 skipped).    ..  ***************
120    2019-02-18 14:44    34  ***************
121    2019-02-18 14:45    33  **************
...    ..( 14 skipped).    ..  **************
136    2019-02-18 15:00    33  **************
137    2019-02-18 15:01    32  *************
...    ..(116 skipped).    ..  *************
254    2019-02-18 16:58    32  *************
255    2019-02-18 16:59    33  **************
...    ..(139 skipped).    ..  **************
395    2019-02-18 19:19    33  **************
396    2019-02-18 19:20    34  ***************
...    ..(  6 skipped).    ..  ***************
403    2019-02-18 19:27    34  ***************
404    2019-02-18 19:28    33  **************
...    ..(  7 skipped).    ..  **************
412    2019-02-18 19:36    33  **************
413    2019-02-18 19:37    32  *************
...    ..(  5 skipped).    ..  *************
419    2019-02-18 19:43    32  *************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              39  ---  Lifetime Power-On Resets
0x01  0x010  4            2931  ---  Power-on Hours
0x01  0x018  6     10310640191  ---  Logical Sectors Written
0x01  0x020  6        91363173  ---  Number of Write Commands
0x01  0x028  6     57052367713  ---  Logical Sectors Read
0x01  0x030  6       346760981  ---  Number of Read Commands
0x01  0x038  6      1961665408  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4            2915  ---  Spindle Motor Power-on Hours
0x03  0x010  4            2912  ---  Head Flying Hours
0x03  0x018  4              61  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               6  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4              37  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              31  ---  Current Temperature
0x05  0x010  1              31  ---  Average Short Term Temperature
0x05  0x018  1              33  ---  Average Long Term Temperature
0x05  0x020  1              41  ---  Highest Temperature
0x05  0x028  1              22  ---  Lowest Temperature
0x05  0x030  1              37  ---  Highest Average Short Term Temperature
0x05  0x038  1              27  ---  Lowest Average Short Term Temperature
0x05  0x040  1              36  ---  Highest Average Long Term Temperature
0x05  0x048  1              33  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4           14214  ---  Number of Hardware Resets
0x06  0x010  4              61  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            1  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            9  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4        43363  Vendor specific
You can get it to display in a code page like this with formatting by enclosing the listing in code tags like this [CODE] list here [/CODE]
Avena
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Vendor specific:
                                ||__ D supports DSN
Avena
root@freenas ~]# smartctl -x /dev/ada2
Model Family: Seagate Barracuda 3.5
Device Model: ST2000DM006-2DM164
Serial Number: Z4ZAPXJA
LU WWN Device Id: 5 000c50 0b062e0ba
Firmware Version: CC26
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Apr 10 22:43:47 2019 -03
APM feature is: Disabled
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 80) seconds.
command.
power-saving mode.
recommended polling time: ( 217) minutes.
SCT capabilities: (0x1085) SCT Status supported.
1 Raw_Read_Error_Rate POSR-- 118 099 006 - 174567528
3 Spin_Up_Time PO---- 098 097 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 69
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 100 253 030 - 729433
9 Power_On_Hours -O--CK 100 100 000 - 123
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 34
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 100 000 - 0 0 0
189 High_Fly_Writes -O-RCK 100 100 000 - 0
190 Airflow_Temperature_Cel -O---K 065 053 045 - 35 (Min/Max 22/35)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 41
193 Load_Cycle_Count -O--CK 100 100 000 - 173
194 Temperature_Celsius -O---K 035 047 000 - 35 (0 22 0 0 0)
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
240 Head_Flying_Hours ------ 100 253 000 - 121h+15m+06.666s
241 Total_LBAs_Written ------ 100 253 000 - 1645818225
242 Total_LBAs_Read ------ 100 253 000 - 332570278
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0xa1 GPL,SL VS 20 Device vendor specific log
0xa2 GPL VS 4496 Device vendor specific log
0xa8 GPL,SL VS 129 Device vendor specific log
0xa9 GPL,SL VS 1 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xb0 GPL VS 5176 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc1 GPL,SL VS 10 Device vendor specific log
0xc3 GPL,SL VS 8 Device vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Version (vendor specific): 522 (0x020a)
Current Temperature: 34 Celsius
Power Cycle Min/Max Temperature: 22/34 Celsius
Lifetime Min/Max Temperature: 22/46 Celsius
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP/SMART Log 0x04) not supported
0x000a 2 2 Device-to-host register FISes sent due to a COMRESET
[root@freenas ~]# smartctl -a /dev/ada2
Local Time is: Wed Apr 10 22:43:54 2019 -03
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 174567528
3 Spin_Up_Time 0x0003 098 097 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 69
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 729462
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 123
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 34
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 065 053 045 Old_age Always - 35 (Min/Max 22/35)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 41
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 173
194 Temperature_Celsius 0x0022 035 047 000 Old_age Always - 35 (0 22 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 121h+15m+14.101s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1645822153
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 332570278
SMART Error Log Version: 1
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas ~]# zpool status
pool: disco2tera
state: ONLINE
scan: scrub repaired 0 in 0 days 00:24:39 with 0 errors on Sun Apr 7 00:24:42 2019
NAME STATE READ WRITE CKSUM
disco2tera ONLINE 0 0 0
gptid/736dd3d2-33a1-11e9-bcbe-001d92e79e75 ONLINE 0 0 0
errors: No known data errors
pool: disco4
state: ONLINE
scan: scrub repaired 0 in 0 days 00:10:03 with 0 errors on Sun Apr 7 00:10:04 2019
disco4 ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/dc417a51-02e0-11e8-b28e-001d92e79e75 ONLINE 0 0 0
gptid/df21d504-02e0-11e8-b28e-001d92e79e75 ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:02:53 with 0 errors on Mon Apr 8 03:47:56 2019
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
