falha de disco
Avena
Senhores,
Sabem me dizer se isso é uma falha física de hd? Ou se pode ser problema no cabo?
Apr 8 01:02:16 freenas ata2: timeout waiting to issue command
Apr 8 01:02:16 freenas ata2: error issuing WRITE_DMA48 command
Apr 8 01:02:16 freenas (ada2:ata2:0:1:0): WRITE_DMA48. ACB: 35 00 08 56 4d 40 47 00 00 00 00 01
Apr 8 01:02:16 freenas (ada2:ata2:0:1:0): CAM status: Command timeout
Apr 8 01:02:16 freenas (ada2:ata2:0:1:0): Retrying command
melloa
Informe configuracao do servidor, controladora de disco, etc.
Execute e check smart para o disco acima. Veja tambem o pool status. Poste resultados.
smartctl -a /dev/ada2
zpool status
Avena
[root@freenas ~]# smartctl -x /dev/ada2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Seagate Barracuda 3.5
Device Model: ST2000DM006-2DM164
Serial Number: Z4ZAPXJA
LU WWN Device Id: 5 000c50 0b062e0ba
Firmware Version: CC26
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Apr 10 22:43:47 2019 -03
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Disabled
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, frozen [SEC2]
Wt Cache Reorder: Unavailable
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 80) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 217) minutes.
Conveyance self-test routine
SCT capabilities: (0x1085) SCT Status supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 118 099 006 - 174567528
3 Spin_Up_Time PO---- 098 097 000 - 0
4 Start_Stop_Count -O--CK 100 100 020 - 69
5 Reallocated_Sector_Ct PO--CK 100 100 010 - 0
7 Seek_Error_Rate POSR-- 100 253 030 - 729433
9 Power_On_Hours -O--CK 100 100 000 - 123
10 Spin_Retry_Count PO--C- 100 100 097 - 0
12 Power_Cycle_Count -O--CK 100 100 020 - 34
183 Runtime_Bad_Block -O--CK 100 100 000 - 0
184 End-to-End_Error -O--CK 100 100 099 - 0
187 Reported_Uncorrect -O--CK 100 100 000 - 0
188 Command_Timeout -O--CK 100 100 000 - 0 0 0
189 High_Fly_Writes -O-RCK 100 100 000 - 0
190 Airflow_Temperature_Cel -O---K 065 053 045 - 35 (Min/Max 22/35)
191 G-Sense_Error_Rate -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 41
193 Load_Cycle_Count -O--CK 100 100 000 - 173
194 Temperature_Celsius -O---K 035 047 000 - 35 (0 22 0 0 0)
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 0
199 UDMA_CRC_Error_Count -OSRCK 200 200 000 - 0
240 Head_Flying_Hours ------ 100 253 000 - 121h+15m+06.666s
241 Total_LBAs_Written ------ 100 253 000 - 1645818225
242 Total_LBAs_Read ------ 100 253 000 - 332570278
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 5 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 20 Device vendor specific log
0xa2 GPL VS 4496 Device vendor specific log
0xa8 GPL,SL VS 129 Device vendor specific log
0xa9 GPL,SL VS 1 Device vendor specific log
0xab GPL VS 1 Device vendor specific log
0xb0 GPL VS 5176 Device vendor specific log
0xbe-0xbf GPL VS 65535 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL,SL VS 10 Device vendor specific log
0xc3 GPL,SL VS 8 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 522 (0x020a)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 34 Celsius
Power Cycle Min/Max Temperature: 22/34 Celsius
Lifetime Min/Max Temperature: 22/46 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Data Table command not supported
SCT Error Recovery Control command not supported
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x000a 2 2 Device-to-host register FISes sent due to a COMRESET
0x0001 2 0 Command failed due to ICRC error
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
[root@freenas ~]# smartctl -a /dev/ada2
Local Time is: Wed Apr 10 22:43:54 2019 -03
been run.
command.
power-saving mode.
1 Raw_Read_Error_Rate 0x000f 118 099 006 Pre-fail Always - 174567528
3 Spin_Up_Time 0x0003 098 097 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 69
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 729462
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 123
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 34
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 065 053 045 Old_age Always - 35 (Min/Max 22/35)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 41
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 173
194 Temperature_Celsius 0x0022 035 047 000 Old_age Always - 35 (0 22 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 121h+15m+14.101s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1645822153
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 332570278
SMART Error Log Version: 1
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
zpool status
been run.
command.
power-saving mode.
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
[root@freenas ~]# zpool status
pool: disco2tera
state: ONLINE
scan: scrub repaired 0 in 0 days 00:24:39 with 0 errors on Sun Apr 7 00:24:42 2019
NAME STATE READ WRITE CKSUM
disco2tera ONLINE 0 0 0
gptid/736dd3d2-33a1-11e9-bcbe-001d92e79e75 ONLINE 0 0 0
errors: No known data errors
pool: disco4
state: ONLINE
scan: scrub repaired 0 in 0 days 00:10:03 with 0 errors on Sun Apr 7 00:10:04 2019
disco4 ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/dc417a51-02e0-11e8-b28e-001d92e79e75 ONLINE 0 0 0
gptid/df21d504-02e0-11e8-b28e-001d92e79e75 ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:02:53 with 0 errors on Mon Apr 8 03:47:56 2019
freenas-boot ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
