Raul Prado
- Jul 24, 2015
Hello all!
This week I received the report email saying a drive failed a s.m.a.r.t. test.
I am wondering if there is a way to go deeper and found whats happening.
The volume status shows all the disks without any failure. The alert si on green. I am ready to replace the disk, but I wanna know what happened.
Thanks for your advice!
My sistem info:
My Volume status:
And the smartctl output:
My sistem info:
My Volume status:
[root@subternia] ~# smartctl -a /dev/da6 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p8 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: WD Product: WD2001FYYG-01SL3 Revision: VR07 Compliance: SPC-4 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Logical block size: 512 bytes Rotation Rate: 7200 rpm Form Factor: 3.5 inches Logical Unit id: 0x50000c0f01d31efc Serial number: WMC160166386 Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Thu Oct 1 18:18:41 2015 CDT SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled === START OF READ SMART DATA SECTION === SMART Health Status: OK Current Drive Temperature: 33 C Drive Trip Temperature: 69 C Manufactured in week 46 of year 2013 Specified cycle count over device lifetime: 1048576 Accumulated start-stop cycles: 159 Specified load-unload count over device lifetime: 1114112 Accumulated load-unload cycles: 5 Elements in grown defect list: 0 Error counter log: Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 15517 11 846 15528 14 81857.645 3 write: 113907 536 540 114443 536 22858.927 0 Non-medium error count: 382 SMART Self-test log Num Test Status segment LifeTime LBA_first_err [SK ASC ASQ] Description number (hours) # 1 Background short Completed - 11311 - [- - -] # 2 Background short Completed - 11264 - [- - -] # 3 Background long Failed in segment --> 6 11232 111755709 [0x3 0x11 0x0] # 4 Background short Completed - 11231 - [- - -] # 5 Background short Completed - 9682 - [- - -] # 6 Background short Completed - 9658 - [- - -] # 7 Background short Completed - 9634 - [- - -] # 8 Background short Completed - 9610 - [- - -] # 9 Background short Completed - 9586 - [- - -] #10 Background short Completed - 9562 - [- - -] #11 Background short Completed - 9538 - [- - -] #12 Background short Completed - 9514 - [- - -] #13 Background short Completed - 9490 - [- - -] #14 Background short Completed - 9466 - [- - -] #15 Background short Completed - 9442 - [- - -] #16 Background short Completed - 9418 - [- - -] #17 Background short Completed - 9394 - [- - -] #18 Background short Completed - 9370 - [- - -] #19 Background short Completed - 9346 - [- - -] #20 Background short Completed - 9322 - [- - -] Long (extended) Self Test duration: 15620 seconds [260.3 minutes]
