I have a few different shares set up on my 9.10 box. They all appear to be working fine, with the exception of the "guest" share always prompts for credentials. When looking at the documentation it mentions to use the Wizard (is it not possible to modify some of these attributes after the share is already created? like the owner) to create a new share and then to chose "nobody" as the owner. When in this screen however I only see "root" as a user to select and no others. I ensured that the "allow guest access" and "only allow guest access" options are enabled/selected in my configuration. Everything else is pretty much the same as my other CIFS shares. I want to keep those the same but have this share open to my entire 192.168.0.x network and to not prompt for any credentials when a user browses to it.
Please let me know if you need any additional information. Thanks in advance.
