Green-Power (scheduled Power-off)
Hello all.
I'k looking for a auto-power-off functionality. My (old) Computer can scheduled power ON. I think FREENAS needs a setup for AUTO-POWER-OFF.
Hope u can add it to 8.1 for a green world :o
you want it to shutoff at a certain time? You could always add an entry to /conf/base/etc/crontab to shut it down yourself at a given time
if you add:
1<tab>2<tab>*<tab>* <tab>*<tab>root<tab>shutdown -p now
to /conf/base/etc/crontab, it should shut the system off at 2:01 am. here is a quick reference for crontab: http://adminschoice.com/crontab-quick-reference
you'll need to mount the file system as writable first, to do this type
mount -uw /
make a backup of your crontab first.
cp /conf/base/etc/crontab /conf/base/etc/crontab.bak
you can then append onto crontab by typing
printf "1\t2\t\*\t\*\t\*\troot\tshutdown -p now" >> /conf/base/etc/crontab
let me know if i need to go into more details for you.
Dear Matt
Many thanks. I have updated to 8.0.1 witch comes with the CRONE-EDITOR and have add your lines. Thanks a lot.
Shutdown
reboot Reboot immediately
halt Shutdown immediately
halt -p Shutdown immediately and turn off power if possible
shutdown -h 5 "Sys maintenance" Halt in 5 minutes, send warning message to logged- in users
numbnuts AU
having this feature included in the GUI like previous version would be good. I schedule a shutdown on week nights at a certain time but leave the NAS running over the weekend, from friday afternoon to midnight on Sunday because thats when we use it the most.
P
philip
Guest
Wouldn't it be even better if we could schedule some type of sleep, or suspend-to-ram mode like "acpiconf -s 3" to power-down the NAS when idle, yet still have it available on demand with WOL ? I imagine most home users could use some form of sleep mode, my NAS just sits idle over 95% of the time burning CPU cycles and heating up the room.
tsatchell
Would be a great feature :)
SoftDux-Rudi
I agree, and would like to vote for this feature as well. Having a standby mode, with instant (or at least near-instant) wake-up would be awesome. It would help a great deal with my backup NAS to save some electricity
sac0dan
That's exactly what I'm looking for for ages now. Until now I started a shutdown after no client host could be pinged. I found such a script in the freenas7-forum and adapted it. Unfortunatly with FN8 it doesn't work properly anymore and I have no clue why not.
So +1 for e "green solution"
Dutchy
sac0dan
What is the script that you're using? Maybe we can fix it?
Here is my script. I got it from the FN7 forum a while ago and adapted it to my needs. Basically it pings a specific range of IPs and shuts down when no host is reachable anymore. It does this after the ping failed for a certain number of tries.
The problem I now have with FN8 is that after a wake on lan the pinging ALWAYS fails. Even if there are some machines active on the intranet the script doesn't 'see' them. I have absolutely no clue why.
Sometimes it completly blocks my NAS so I have to do a hard reset. I don't know exactly what's happening.
#!/bin/bash
lockfile=/tmp/autosuspend.lock
if [ ! -e $lockfile ]; then
   trap "rm -f $lockfile; exit" INT TERM EXIT
   touch $lockfile
	echo "autosuspend script started"
	#sleep 180     # Sleep for 3 mins to make sure the server don't shut down right away
	class=192.168.1
	myIP=192.168.1.10   #$(/sbin/ifconfig | egrep -o "192.168.1.[0-9]{1,3}")
	failcount=0
	maxfail=3       # Set the number of failure count before we do a shutdown
	SLEEP=600       # Numbers of seconds between each check/loop
	LOGFILE=/tmp/autosuspend.log
	# Don't suspend if one of the following processes is active (separate by space):
	STOPPROCS='storeBackup wget'
	echo Logfile=$LOGFILE
	unset known_host
	_ping_last_host() {
	  # try to ping the last known active host
	  # return 0 on success, otherwise 1
	  echo "pinging last host $known_host" >> $LOGFILE
	  if [ $known_host ]; then
		echo -n "`date` - pinging last host $known_host - " >> $LOGFILE
		ping -c 1 $known_host >/dev/null;
		if [ $? -eq 0 ]; then
		  echo "host is active" >> $LOGFILE
		  # Jepp! We're done
		  return 0
		else
		  echo "fail" >> $LOGFILE
		  unset known_host
		  return 1
		fi;
	  else
		return 1
	  fi
	_ping_range() {
	  # Ping an IP-range and look for a responding host.
	  # If there is one store it's IP in $known_host and return 0
	  cnt=0
	  echo "`date` - pinging range...  " >> $LOGFILE
	  for i in {2..14}; # Set the range
	  do
		# Ignore my own ip
		if [ ${class}.${i} != $myIP ]; then
		  echo "pinging ${class}.${i}" >> $LOGFILE
		  ping -c 1 ${class}.${i} >/dev/null
			echo -n "${class}.${i} - " >> $LOGFILE
			known_host=${class}.${i}
			return 0;
		  fi
		fi
	  done
	  return 1
	_shutdown() {
	  # Do a shutdown if we failed for $failcount rounds
	  # We need a script suspend.sh in the current directory
	  echo "deciding doing shutdown or not. failcount = $failcount" >> $LOGFILE
	  if [ $failcount -eq $maxfail ];then
		echo "`date` - doing a shutdown" >> $LOGFILE
		more $LOGFILE | grep -F --line-buffered ''  # clear buffer
                rm $lockfile
                trap - INT TERM EXIT
		shutdown -p now >>$LOGFILE
		#we will never arrive here with a shutdown...
		echo "`date` - back from suspend" >> $LOGFILE
		failcount=0;
	  fi
	while [ 1 ];
	do
	  proc_found=0
	  # look if uniterruptable jobs are running
	  for proc in $STOPPROCS
	  do
		if [ "`pgrep $proc`" != "" ];then
		  echo "`date` - $proc is running." >> $LOGFILE
		  proc_found=1
		  break
		fi
	  done
	  echo procfound=$proc_found
	  if [ $proc_found -eq 0 ]; then
		# look for other hosts, that are alive in our subnet
		_ping_last_host
		if [ $? -ne 0 ];then
		  _ping_range
			let failcount++;
			echo "failure No. $failcount" >> $LOGFILE
			_shutdown;
		  else
			echo "good." >> $LOGFILE
			failcount=0;
		  fi
		  else
			failcount=0;
		fi
	  fi
	  sleep $SLEEP;
	done
   rm $lockfile
else
   echo "autosuspend is already running. Exiting."
fi
EDIT: Found the problem, corrected the script. Please read the following articles. And make sure your Windows firewall isn't blocking ping requests (that's what Windows 7 by default does...).
sac0dan
After months I finally found the culprit. Perhaps someone can benefit of my field report.
To be exactly there were two reasons why my script didn't work anymore:
First Windows 7 firewall does BLOCK ping requests by default. So my script couldn't reach my main computer in the intranet and tried to shutdown too early.
Second: I always thought FN would crash or block while trying to shutdown as the vents were blowing louder than in idle mode while the host wasn't reachable over the intranet anymore. Last week I once again checked the manpage of "shutdown" and found that on some hardware you need the option "-p" instead of "-h" to get a power off. Then I remembered to have also changed the hardware while going from FN7 to FN8. After I exchanged the -h with a -p it works.
So the script I posted here several days ago works.
ProtoSD
Don't feel bad Sac0dan, I've been accustomed to using -h also and was caught off guard with -p :)
Thanks for the update!
