ian351c
- Oct 20, 2011
Is there any way to have more granular control over syslog-ng in FreeNAS? Doesn't look like there's much in the GUI (and I'm OK with that). It looks like any time the syslog parameter is changed under System > General, a new syslog-ng.conf is created in /etc/local. I was hopeful when I found /etc/local/syslog-ng.conf.freenas, which I hoped was where the "base config" was copied from (and where I might permanently store changes to be copied to syslog-ng.conf), but alas, this does not appear to be the case.
Does a "gold copy" of syslog-ng.conf exist somewhere else on the file system that I might edit? Or is it generated programmatically?
Thanks.
Thanks.
