Get Plugins Failed-11.3-u4.1
moranshe
Newbie
fresh install :
Cmd('git') failed due to: exit code(128) cmdline: git clone -v https://github.com/freenas/iocage-ix-plugins.git /mnt/WD3TB/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git stderr: 'Cloning into '/mnt/WD3TB/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git'... fatal: unable to access 'https://github.com/freenas/iocage-ix-plugins.git/': SSL certificate problem: certificate is not yet valid '
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 1566, in _clone_repo
repo = git.Repo(destination)
File "/usr/local/lib/python3.7/site-packages/git/repo/base.py", line 131, in __init__
raise NoSuchPathError(epath)
git.exc.NoSuchPathError: /mnt/WD3TB/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run
await self.future
File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 387, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/jail.py", line 409, in available
plugins_versions_data = IOCPlugin(branch=branch, git_repository=plugin_repository).fetch_plugin_versions()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 266, in fetch_plugin_versions
self.pull_clone_git_repo()
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 137, in pull_clone_git_repo
depth, self.callback
File "/usr/local/lib/python3.7/site-packages/iocage_lib/ioc_plugin.py", line 1631, in _clone_repo
k: v for k, v in kwargs.items() if v
File "/usr/local/lib/python3.7/site-packages/git/repo/base.py", line 988, in clone_from
return cls._clone(git, url, to_path, GitCmdObjectDB, progress, **kwargs)
File "/usr/local/lib/python3.7/site-packages/git/repo/base.py", line 939, in _clone
finalize_process(proc, stderr=stderr)
File "/usr/local/lib/python3.7/site-packages/git/util.py", line 333, in finalize_process
proc.wait(**kwargs)
File "/usr/local/lib/python3.7/site-packages/git/cmd.py", line 415, in wait
raise GitCommandError(self.args, status, errstr)
git.exc.GitCommandError: Cmd('git') failed due to: exit code(128)
Samuel Tai
Typically, this is because your FreeNAS system can't resolve github.com in DNS. Do you have DNS servers and a default gateway defined in Network->Global Configuration?
moranshe
Newbie
hi Samuel
Yes the DNS servers are configured if I ping to GitHub I've got replay
root@freenas[~]# ping github.com
PING github.com (140.82.118.4): 56 data bytes
64 bytes from 140.82.118.4: icmp_seq=0 ttl=54 time=73.754 ms
64 bytes from 140.82.118.4: icmp_seq=1 ttl=54 time=72.419 ms
64 bytes from 140.82.118.4: icmp_seq=2 ttl=54 time=72.551 ms
64 bytes from 140.82.118.4: icmp_seq=3 ttl=54 time=80.575 ms
64 bytes from 140.82.118.4: icmp_seq=4 ttl=54 time=76.668 ms
64 bytes from 140.82.118.4: icmp_seq=5 ttl=54 time=72.966 ms
64 bytes from 140.82.118.4: icmp_seq=6 ttl=54 time=73.666 ms
Samuel Tai
OK, the error code triggered was: SSL certificate problem: certificate is not yet valid. Is your system sync'ed to NTP? Is the local time correct? See this thread on a locally drifting clock.
moranshe
Newbie
you are correct, the time wasn't sync with the NTP servers
I set the NTP to ntp.org servers and now it's work fine thank you
