Dear community,
I build up today my backup server with 7x SAMSUNG HD203WI (2TB) disks. They have a physical and logical sector size of 512b.
e.g.
I created an encrypted pool by the Freenas-WebGUI. Unfortunately the WebGUI used the wrong sector size "4096" for ashift:
The correct ashift should be 9 for 512b.
So I tried to change it via sysctl in /etc/sysctl.conf:
After recreating the pool I checked it again:
zdb -U /data/zfs/zpool.cache | grep ashift
I tried to find the trouble maker. After a time I double checked it with the geli:
geli dump /dev/gptid/faff3127-79a5-11ea-9a87-50e54938d02e
The FreeNAS-Webgui / geli choose the wrong sector size of the underlaying provider => 4096 instead of 512.
Regarding this post:
"It defaults to reported sector size of the underlying provider, so 512
bytes, I guess. In my opinion 4096 is optimal. Larger sectors are
problematic, because if sector size it is larger than page size various
tools will have problems with mmap(2)ing files." - source: https://lists.freebsd.org/pipermail/freebsd-geom/2011-April/004739.html
I have to switch the geli sector size to 512. How can I do it without a script. Is there any way to configure geli to use my wished sector size of 512 as default?
Anyway, is it strictly recommended to set the ashift to 9 for 512b sector size? Does it have a huge performance impact? I read already that ashift=12 is recommended for future purposes (hdd change). That isn't planned.
Kind regards,
peacepipe
e.g.
camcontrol identify ada0 pass0: <SAMSUNG HD203WI 1AN10003> ATA8-ACS SATA 2.x device pass0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) protocol ATA8-ACS SATA 2.x device model SAMSUNG HD203WI firmware revision 1AN10003 serial number S1UYJ1AZ808264 WWN 50024e9003f128cc additional product id cylinders 16383 heads 16 sectors/track 63 sector size logical 512, physical 512, offset 0 LBA supported 268435455 sectors LBA48 supported 3907029168 sectors PIO supported PIO4 DMA supported WDMA2 UDMA6 media RPM 5400 Zoned-Device Commands no ...
ashift: 12
vfs.zfs.min_auto_ashift=9
vfs.zfs.vdev.larger_ashift_minimal=0
ashift: 12
Metadata on /dev/gptid/faff3127-79a5-11ea-9a87-50e54938d02e:
magic: GEOM::ELI
version: 7
flags: 0x0
ealgo: AES-XTS
keylen: 256
provsize: 1998251364352
sectorsize: 4096
keys: 0x01
iterations: -1
Kind regards,
peacepipe
