FTP was working until I added syslog dataset
Jeren
I wanted saving of logs so I made a dataset called syslog. Great. I see all my logs there and everything almost works as it should.
Problem: FTP no longer starts up; gives me the error
freenas notifier: proftpd not running?
freenas notifier: Starting proftpd.
freenas notifier: freenas.local proftpd[35512]: Fatal: SyslogFacility: unable to open syslog: Operation not permitted on line 10 of '/usr/local/etc/proftpd.conf'
freenas root: /usr/local/etc/rc.d/proftpd: WARNING: failed to start proftpd
freenas notifier: /usr/local/etc/rc.d/proftpd: WARNING: failed to start proftpd
my /usr/local/etc/proftpd.conf looks like
ServerName "freenas.local FTP Server"
ServerType standalone
DefaultServer on
#Default Address freenas.local
UseIPv6 on
Port 21
User nobody
Group nogroup
Umask 062 022
SyslogFacility ftp
MultilineRFC2228 off
DisplayLogin /var/run/proftpd/proftpd.motd
DeferWelcome off
TimeoutIdle 600
TimeoutLogin 300
TimeoutNoTransfer 300
TimeoutStalled 3600
MaxInstances none
MaxLoginAttempts 3
DefaultTransferMode ascii
AllowForeignAddress off
IdentLookups off
UseReverseDNS off
<Anonymous /mnt/URANAS>
  User ftp
  Group ftp
  UserAlias anonymous ftp
  <Limit LOGIN>
    AllowAll
  </Limit>
</Anonymous>
<Limit LOGIN>
  AllowAll
</Limit>
<Global>
  RequireValidShell off
  DefaultRoot ~ !wheel
#  RootLogin on
  AllowOverwrite on
#  AllowRetrieveRestart on
#  AllowStoreRestart on
  DeleteAbortedStores off
  TimesGMT off
</Global>
<IfModule mod_ban.c>
  BanEngine off
  BanControlsACLs all allow group wheel
  BanLog /var/log/proftpd/ban.log
  BanMessage Host %a has been banned
# -m "mod_ban/rule"
# -v "concat('  BanOnEvent ',event,' ',occurrence,'/',timeinterval,' ',expire)" -n
# -b
  BanTable /var/run/proftpd/ban.tab
</IfModule>
<IfModule mod_delay.c>
  DelayEngine on
  DelayTable "/var/run/proftpd/proftpd.delay"
</IfModule>
<IfModule mod_wrap.c>
  TCPAccessFiles /etc/hosts.allow /etc/hosts.allow
  TCPAccessSyslogLevels info warn
  TCPServiceName ftpd
</ifModule>
Line 10 corresponds to
SyslogFacility ftp
and I can only guess that there is some logging shenanigans going on. If I delete line 10 and try to start ftp again from the services tab, I get the same error and the proftpd.conf file seems to restore itself and render any previous changes void.
I cannot delete the syslog dataset because it is perpetually busy (tried turning off all plugins, jails, and servies). Is there a way to get my FTP back?
Jeren
Issue number 3218 has been created
paleoN
The file is generated on service start. To test the change start the service from the CLI.
To delete the dataset:
  1. Boot into single user mode
  2. # sh /etc/rc.initdiskless
  3. # zpool import -R /mnt poolname
  4. # zfs destroy poolname/syslog
  5. # shutdown -r now
Jeren
It works now, ended up deleting line 10 from /usr/local/etc/proftpd.conf and adding
proftpd_enable="YES"
to /var/tmp/rc.conf.freenas and /etc/rc.conf
service proftpd start now correctly works without giving me errors
enemy85
I have the same problem you had...let's try and hope it works for me too
enemy85
it doesn't work for me...
- I try to access via SSH in root mode
- i do "mount -uw /"
- i do all the steps u say
- i do "mount -ur /"
and it won't work
- i restart freenas
it keep not working + if i go to check /usr/local/etc/proftpd.conf the line 10 is again there...
where do i go wrong???
Jeren
What sort of errors did you get?
Sometimes after I run
it doesn't work immediately and I have to go back to /usr/local/etc/proftpd.conf, delete line 10, add proftpd_enable="YES" to /etc/rc.conf, and CHANGE proftpd_enable="NO" on line 9 to proftpd_enable="YES" in /var/tmp/rc.conf.freenas. I run
again and it starts up without problems.
enemy85
Hi jeren, thank you for the answer.
Well i don't get a specific error, it just keep not working saying the same things
  1. freenas notifier: proftpd not running?
  2. freenas notifier: proftpd not running?
  3. freenas notifier: Starting proftpd.
  4. freenas notifier: freenas.local proftpd[35512]: Fatal: SyslogFacility: unable to open syslog: Operation not permitted on line 10 of '/usr/local/etc/proftpd.conf'
  5. freenas root: /usr/local/etc/rc.d/proftpd: WARNING: failed to start proftpd
  6. freenas notifier: /usr/local/etc/rc.d/proftpd: WARNING: failed to start proftpd
    I'll try again, but the problem is just that every time i do that it doesn't work, then i restart the nas and the line 10 in
    /usr/local/etc/proftpd.conf, is again there as it didn't save the changes...
enemy85
well, i did all the tries i could...
if i do exactly what u suggest to do, and than run
  1. service proftpd start
from the shell, the ftp start to work, but if i reboot the nas, we are at the same point of the beginning...it doesn't keep the changes...how do i solve this?
I even tried to delate the syslog dataset doing:
  3. # zpool import -R /mnt/DATI
  4. # zfs destroy DATI/syslog
but it doesn't delate anything because it says "no such dataset found"....
paleoN
enemy85
i have to do the zfs list after the import right? like this?
  4. zfs list
    I'll try this afternoon and let u know, now i don't have the Nas here with me
enemy85
well i tried...and if i do
  4. zfs list
the system reply "no datasets available"...
paleoN
enemy85
Yes "DATI" is the name of my zpool.
I tried the exact command the first time, but i got an error, that's why i changed in /DATI
I'll try again and let u know. Thanks for the help
enemy85
The error is:
"cannot import 'DATI': no such pool available"
paleoN
The error is:
Not that you provided any actual details of your pool, but guessing I would say it doesn't see the disks. You likely need to load some module first.
It may be sufficient to boot normally, stop syslogd and delete the dataset. I haven't actually tested it though.
service syslogd stop
enemy85
My nas it's a really basic one, with just 2x2tb disk mirrored on an amd e350 pure mini mobo and 4gb ram
paleoN
Are the drives internal and connected directly to the motherboard? If so and stopping syslogd isn't enough:
zpool import
zpool status
camcontrol devlist
gpart show
glabel status
enemy85
Yes the drives are internal and connected directly to the mobo. Tomorrow i'll try both ur solutions and report what happens to you. Thanks
