FTP usage with Filezilla - unable to go on parent directory
isagarran
Configuration :
  • MotherBoard socket 1155 MSI H67MA-E35 (Revision B3).
  • FreeNAS FreeNAS-11.0-U3 (c5dcf4416)
  • 6 disks Seagate Barracuda 2Tb
  • Memory 8Gb
  • OCZ PSU ZS550W-EU - ZS Series, 550W 80Plus Bronze
  • Processor Intel® Celeron® Processor G530 (2M Cache, 2.40 GHz)
  • I intent to configure RAIDZ2 as advised by senior FreeNAS
  • CD/DVD device for installation
  • SSD SATA device connected as USB device
I tried to FTP backuped data to Freenas server. I created a ZFS volume Configuration : volume_name/Share_name/FTPuser
This is also the home directory of FTPuser.
My problem is that I would like to use to copy data on volume_name/Share_name, create directories and so on.
I ran the command setfacl -b /volume_name/Share_name/FTPuser
Using Filezilla, I'm unable to go on /volume_name/Share_name
Could you tell me how to do that ?
regards
Isagarran
Chris Moore
It sounds to me like you need to change the home directory for your ftp user. The system is designed to not allow you to access directories above the ftproot as those are not shared to the ftp service.
