FTP create directory: Operation not permitted
Myopia
Hi all,
I hoped to enjoy my new nas more with Freenas, but unfortunately there are some bears to shoot.
My configuration:
1 volume: redz
1.1 dataset: redz\media
1.2 dataset: redz\reddataset
Group 1004 admin
User 1002 media homedir: redz\media
User 1003 reddataset homedir: redz\reddataset
Users have all checkboxes checked read write execute
User have Auxiliary groups: admin;ftp
FTP
path: mnt\redz
allow local user login checked
File permission all is checked for read write
Directory permission all is checked for read write execute
I can upload files and create new files. But when I create a directory I get the following error:
Response: 550 DIRNAME: Operation not permitted
Jan 19 17:52:30 freenas proftpd[65302]: 127.0.0.1 (192.168.1.121[192.168.1.121]) - chmod(/s/.dstOUvNtkFO) failed: Operation not permitted
Why can't I create directories?
anodos
Sambassador
You have the permissions type set to "windows". This prevents you from being able to chmod files. FYI, you shouldn't share the same dataset via FTP and CIFS simultaneously. The FTP server doesn't understand windows oplocks, which are used to agressively cache things client-side, and it can lead to file corruption.
Myopia
I want to have one dataset MEDIA which I can access via FTP and CIFS. But after reading your comment, this is not possible? Is there a solution to deal with this approach? Different filesystem?
anodos
Sambassador
It's better to just select a single method of sharing files and stick with it. Use a VPN to provide remote access (if needed).
Maranatha
I found a quick and dirty fix for this... I too wanted to share a volumn with both FTP and CIFS.
I wanted CIFS readonly and FTP as my upload.
My issue was that I created with Windows permissions to begin with and no matter what I did with freenas GUI, I couldn't change that to Unix.
I checked with the shell and everything still had "+" at the very end.
So I ended up forcefully dropping all Windows ACL with this from that root directory of my volumn:
find . -exec setfacl -b {} \;
If anyone is out to try quick and dirty fix... welcome to try this. But I will not take any responsibility for any loss of data (not that changing permission would do that).
Feel free to suggest me better solution if anyone has one. Thanks!
anodos
Sambassador
It's probably a better idea to specify the path to the directory you wish to run this command on. Also, you will need to be careful what actions you perform from the FreeNAS webgui as some actions will set a non-trivial ACL on the samba share.
SweetAndLow
Sweet'NASty
Do you have jails? Do they still work after running this?
